Question about Brother ML-100 Typewriter
I am working on a little project to use the print mechanism from a brother typewriter (ML-100). Unfortunately, I have been unable to find service manuals anywhere for this typewriter. My current q
I've pulled out the print head and examined it closely, but so far I haven't found the mechanism. I am wondering if it has something to do with a second pinion gear that's on the bottom of the print head, that follows the same rack gear that is used by a different pinion gear to move the print head. Thanks for reading this!
    New Friend:
    Problem Solver:
I found a small piece of plastic caught under neath the carriage
of my Brother GX-6750 Electronic Typewriter. The piece looks as if it slipped onto some type of small end cylindrical peg one sixteenth long and one thirty-seconds in diameter. The piece has a lip where it latches on to something and the other end is flat with a tiny edged lip. The middle piece is where some peg goes into it and the piece is one piece. The carriage works improperly and fails to type. The hammer mechanism won't move forward on it's pivot to punch the daisy wheel. When the keys get punched, nothing happens. I just bought the GX-6750
through ebay and it arrived that way today. I'm looking for suggestions to get it fully operable.
Posted on Dec 09, 2014
JUSTOLDJIM
  • 478 Answers
SOURCE: Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Posted on Jan 23, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
SOURCE: Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Posted on Oct 03, 2009
cautionflag1
  • 116 Answers
SOURCE: Carriage Return Inconsistency
It has been a while since I have seen a #5 Underwood. I think I still have one hidden in the attic that the wife thinks was thrown out long ago :).
The carriage return is done by the lever that pushes a pawl. The pawl engages in the ratchet teeth on the LH end of the platen. If the typewriter has the half-space feature, then it has to roll the platen two clicks (teeth) for a line space. The problems were usually in two places when this didn't happen correctly. The first is that the bushings on the platen were dry and needed oiling. The second was the follow-up roller is not clicking into the ratchet tooth and keeping it latched in the proper position. Because the platen doesn't roll far enough, or is free enough, the roller stops on top of a tooth instead of clicking into the space between the teeth. This can be caused by dry platen bushings, sticky follow up roller mechanism, or weak follow up roller spring. If you roll the typewriter on its back with the carriage all the way to the left, you should be able to pull the carriage return and watch the follow up roller action from underneath (you may need a flashlight). A light weight oil (Marvel Mystery or a sewing machine oil or Triflow) will be suffiecient to fix it usually. Put a few drops in the bushing where the steel platen shaft goes thru the end of the carrier and a few drops around where the mechanism that attaches the follow up roller to the end of the carriage. Roll the platen back and forth to work it in then slide the carriage to the right and do the shaft on the other end and work it again. Hopefully that will take care of it. If it doesn't, then the spring will have to be tightened by removing a loop. Depending on your mechanical ability and tools, that can be an easy or difficult job.
I didn't mean to write a book on the subject. I worked on mechanical typewriters years ago and hated to see them go to the wayside. I usually don't do this, but if I can be of anymore help, email me :cautionflag1956 at yahoo
Hope this helps
Posted on Jun 13, 2010
  • 3594 Answers
SOURCE: Display Screen reads "4check printer". Carriage
Check the printwheel to be sure it is properly installed. Remove the ribbon and L/O tape and try it, you are looking for anything in the way of the P/W or carroer.
DickyO
Posted on Feb 22, 2011
How does the print head on a Brother ML-100 sense when it has reached the left hand side after a carriage return?
when the print head reaches the left side it touches a switch to cause it to inter the setup for the print wheel and ribbon mechanism
Dec 06, 2014 | Brother ML-100 Typewriter
How to change fonts on a brother typewriter ml 100
TO CHANGE THE FONT YOU MUST CHANGE THE PRINT
WHDickyO
Aug 16, 2014 | Brother ML-100 Typewriter
Lost manuel need one please.
dear sueb ratliff
typerwriters of brother ML series all have same working operations hence their manuals are almost same go to this link http://www.manualnguide.com/download/manual-guide/brother-ml-300-typewriter-users-manual.html to find manual for ML-500 series...
Jun 22, 2011 | Brother ML-100 Typewriter
Brand new typewriter ML-100 worked fine yesterday. Today, letters are not fully appearing; the ink is only filling in half of each letter printed (just the top portion.) Please help. Thank you!
Hi. There is a lever (left side) to set the thickness of paper. Move that to lower number if you only have 1 paper, move up if you have several pages. Hope this helps.
Feb 03, 2011 | Brother ML-100 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Change font size on my bother ML 100
A typewritter is not like a computer. It is a mechanical device, that works by pressing an embossed letter in the daisy wheel through a inked tape into the paper.
The only way you can change either the font type or the font size is by buying and replacing the daisy wheel by another one with different font type/size letters.
To get to know more about your typewritter and accessories that might still be available to it, download Brother ML-100 Typewriter User's Manual
Click on "Go to View/Download Page" and in the new page click the "View/Download" button.
Look for page 16 (last page) of the manual for a list of cassette daisy wheels.
Aug 22, 2009 | Brother ML-100 Typewriter
Not printing
The Brother portable typewriters are pure junk. No longer suported by Brother. Next time spend a little more money and purchase a Nakajima typewriter.
May 13, 2008 | Brother ML-100 Typewriter
HAVING TROUBLE PUTING IN THE CORRECTION TAPE
Make sure you are installing the tape with the sticky side facing the paper. I
May 05, 2008 | Brother ML-100 Typewriter
WON'T PRINT LETTERS
There is a clutch drive that releases the hammer to strike. Probably needs to be replaced. Unfortunately, probably not worth repairing.
Jul 03, 2007 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
