Question about Proscan Televison & Video
I have a proscan tv.It has been giving me problems.When I want to change the channel.Instead of it doing so,it turns the volume up or down.When I want to turn the volume up or down, it change the chan
I have tried to switch remotes.I have tried looking for the companys number.
    Top Expert:
  • Proscan Master
  • 75,417 Answers
Are you using a universal remote control with this TV? Might be. If so, try to set it with an other code said to Sanyo Tv; with your remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 06, 2014
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
trintek
  • 111 Answers
SOURCE: TV CHANGES CHANNELS (BY ITSELF)
is this tv the same model/brand? far be it from me to claim poltergeists are at work, but who knows... the very first thing i would do in diagnosing this issue is to grab some electrical tape and aluminum foil, tape a patch over the ir receiver for the remote, this should be a shiny piece of black plastic somewhere on the front of the tv, some are marked, some are not.. if you have it, aluminum duct tape works great for this purpose.
to me, it seems like someone is messing with you using a remote, tv-b-gone, or similar product like a keychain universal remote.. if the tape over the ir sensor fixes the issue, i would look at roommates, kids, neighbors, or possible interference from other ir or light sources..
possible culprits would be:
universal remotes
dirty remotes that keep sending a signal with nobody using it
laptops or cellphones with an irda port
palm devices such as palm, clie, etc that have irda
intermittent strobes (emergency vehicles, bad ballast in a light fixture, etc)
i can't guarantee this is your problem, but it seems like it since this is your second tv with the same or similar problem... as a sidenote, the sony clie came with a universal remote program, i caused much chaos in my local video stores by shutting down their video wall while browsing.
Posted on Nov 16, 2007
SOURCE: Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
Posted on Jun 04, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
Program directv remote to do everything to Proscan 43LA45H
It may not control all functions for tv ,only on,off , vol, not menu auto program... try www.directtv.com .
Sep 26, 2014 | Proscan 42LA45H 42 in. LCD TV
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
John
Dec 15, 2008 | Proscan 32LA30Q Television
Regarding the one for all remote
Hello mommy,
If you purchased the One-for-All universal remote (model URC4220) the remote code for a Proscan TV is either 0047 or 0747. The instruction booklet also has a section called ''Troubleshooting", which gives specific instructions on how to correct the problems you are having with volume and channel selection.
If you did not purchase the remote control listed above, please tell me the brand name and model number of your remote. I also need to know if it is a universal remote or not.
Hope this info helps you out. Please take a moment, whenever possible, to rate this solution, by using the rating system below.
Thanks.
Aug 20, 2008 | Proscan 19LA25Q 19 in. LCD Television
RCA Proscan TV
I am so sorry, but that board is Way out of production. You might try service forums for Thompson or Proscan. What kind of problem is there with the old one?
Mar 09, 2008 | Televison & Video
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
