Question about LG Stack kit for the front control laundry Pearl Gray
CLEANTHE TRAYS WHERE U PUT THE BLEACH IN AND THE FABRIC SOFTER DO YHEY COM OUT
WANT TO CLEAN THE TRAYS FOR SOAP ,BLEACH AND FABRIC BUT CAN'T GET THEM OUT,DO THEY COME OUT
  • 3 Answers
Yes, press down on the blue bar at the back to release the catch
Posted on Dec 12, 2014
FixinFax
  • 3085 Answers
SOURCE: For the
Bleach ONLY.
Posted on Nov 08, 2009
SOURCE: Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Posted on Sep 24, 2010
richroth
  • 9472 Answers
SOURCE: which compartment does bleach, soap and fabric
Here is the manual for your machine but it is in French. I hope you can read French. Google has this translate program you can use. I hope this helps you.
Posted on Feb 04, 2011
  • 6277 Answers
SOURCE: The soap/bleach/fabric softner compartment is
To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of those should enable you remove it???
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 04, 2011
  • 6277 Answers
SOURCE: Soap/bleach/fabric softner dispenser compartment is
Please see your other posting ;-0)
Thanks, John C
How to clean soap dispensers on hotpoint washing machine
use very warm water and bleach then put mech on final rinces no clothes and let it go through cycle
Mar 02, 2015 | Hotpoint Washing Machines
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My front-loading Kenmore washer's bleach and fabric softer dispenser trays are clogged. Does this entire drawer come out so I can clean?
should be able to pull drawer out completely. pull it out as far as it will go. you should see a little lever you can deprese at right rear to pull drawer all the way out.
Jun 24, 2009 | Washing Machines
Bleach and Fabric softer will not dispense
I had the same problem. I took a sewing pin and stuck it up into the holes at the top and really dug around in there. There was a bunch of slimy gunk in there but works fine now.
Mar 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Constant smell and now displays rl
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
Dec 17, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machine Smell
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Sep 16, 2007 | Washing Machines
LG Stack kit for the front control laundry Pearl Gray Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
