Question about IBM Correcting Selectric III Electric Typewriter
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
HAVE INSTALLED THE CORRECTION TAPE ON THE IBM CORRECTING SELECTRIC III. IT WILL NOT CORRECT THE PRINT.
  • 35 Answers
Theres a manual here that should tell you everything you need to know.
Posted on Dec 08, 2014
  • 3594 Answers
SOURCE: IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
Posted on May 28, 2009
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
  • 3594 Answers
SOURCE: Ibm Selectric iii Correction button not working
Tou do know that tou have to repress to key you are trying to correct. If you know that then the mech. under the rt. dust cover is probably gummed up try some WD40 on it.
DickyO
Posted on Oct 30, 2009
  • 3594 Answers
SOURCE: IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
DiclyO
216-241-0027
Posted on Feb 01, 2010
  • 3594 Answers
SOURCE: IBM Wheelwriter correction tape will not lift off
You may have a very old L/O or ribbon. The ribbon may be a non correctable the knob must be orange, yellow or violet. Not blue or red.
DickyO
Posted on Mar 31, 2010
On the R. side of the carrier there is a gray lever, pull on it to release the tape. Put the full spool on the L. black supply spindle thru the black trianglar shaped lifter, to the rear of the black of the black finger, and put the take up spool on the R. spindle, turn to take up slack, close the gray lever.
DickyO
Dec 05, 2014 | IBM Correcting Selectric III Electric...
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
Correction tape won't work. correction key works. read your comment on wd40, but won't wd40 gum up the works?
do not use WD40 an any typewriter. Are you pressing the letter you want lifted of after the correction key> Is the dull side of the lift off tape facing away from you?
Jun 30, 2014 | IBM Correcting Selectric Iii Typewriter...
DiclyO
216-241-0027
Jan 29, 2010 | IBM Office Equipment & Supplies
Ibm Selectric iii Correction button not working. Correction tape won't lift up. What part need to be replace to fix problem
DickyO
Oct 30, 2009 | IBM Wheelwriter 30 Typewriter
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric III Electric Typewriter Logo
147 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
