Question about IBM Correcting Selectric III Electric Typewriter
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
HAVE INSTALLED THE CORRECTION TAPE. IT WILL NOT CORRECT THE PRINT.
  • IBM Master
  • 3,594 Answers
On the R. side of the carrier there is a gray lever, pull on it to release the tape. Put the full spool on the L. black supply spindle thru the black trianglar shaped lifter, to the rear of the black of the black finger, and put the take up spool on the R. spindle, turn to take up slack, close the gray lever.
DickyO
Posted on Dec 11, 2014
  • 3594 Answers
SOURCE: correction tape on wheelwriter 3
The correction cassette snaps on the bottom of the ribbon. The two little "feet" on the cassette slide over the small tabs on the ribbon and the ribbon clips on.
Hope this helps
DickyO
Posted on Apr 24, 2008
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
  • 3594 Answers
SOURCE: How do you install the correction tape? Any instructions.
Is it a Wheelwriter or a selectric?
DickyO
Posted on Aug 18, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Feb 18, 2010
Testimonial: "I tried wiggling the gear, but it wouldn't budge. So, I pulled it out, toward the right. It popped back into place and started lifting the ribbon."
  • 3594 Answers
SOURCE: IBM Wheelwriter correction tape will not lift off
You may have a very old L/O or ribbon. The ribbon may be a non correctable the knob must be orange, yellow or violet. Not blue or red.
DickyO
Posted on Mar 31, 2010
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
I installed the correction tape and it does not correct
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
Jan 02, 2014 | Brother ML-300 Typewriter
Zebra S600 not printing..replaced ribbon withe as paper/ribbon light solid..still no print after attempting reprint many times (the printing result are white labels)
Just a thought, Zebra Ribbons are Coated Side Out. Take a piece of tape and press it against the ribbon, ink should come off on the tape.
If not then make sure the ribbon is the correct type and that you have it loaded properly. Also, if you use multiple ribbons i.e. wax, wax resin or resin make sure that you have the correct ribbon for the media installed.
Hope that helps.
mikeo@acebarcode.com
www.acebarcode.com
Aug 21, 2011 | Zebra Stripe S400 Label Printer
I am having problems changing the correctable ribbon. It does not correct after installation.
if it prints but doesn't correct, it is probably a problem with the correction tape. make sure the tape is instaled in the correct postion with the dull side towards the paper
Mar 14, 2011 | Brother GX-6750 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
IBM Wheelwriter correction tape will not lift off print. New correction tape installed.
DickyO
Mar 31, 2010 | IBM Wheelwriter 30 Typewriter
I can't get the correction tape to work.. I put it in 1st then the print tape, I'm using Brother brand tapes. .
If the correction does all the movements it is supposed to make and won't lift off you may have a non correctable ribbon or the L/O may be installed wrong the dull side must face the paper.
DickyO
Mar 30, 2010 | Brother SX-4000 Typewriter
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
IBM Correcting Selectric III Electric Typewriter Logo
76 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
