Question about LG LSC26905TT Side by Side Refrigerator
I have an LG side by side refrigerator. It won't stop making ice. The arm on the front of the tray is all the way up and it won't go down. It stays up all the time. Any suggestions
    Novelist:
  • 135 Answers
Http://www.searspartsdirect.com/ replace the ice maker would be the simplest. If you're a good DIY'er, shut off the water to the icemaker, remove the maker and try your skills at troubleshooting the unit. The timer on the icemaker is suspect as it controls the water valve. The wire bail you mention only tells the ice maker that the tray is full and to stop making ice by stopping the timer until you push the bail back down. My guess is that the timer motor failed and stopped just as the water was turned on, BAD TIMER!
Posted on Dec 06, 2014
SOURCE: LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Posted on Mar 08, 2009
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
SOURCE: LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Posted on May 07, 2009
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Posted on Aug 28, 2009
  • 13 Answers
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Posted on Mar 21, 2010
I have an LG side by side refrigerator. It wont stop making ice. The arm on the front of the tray is all the way up and it wont go down. It stays up all the time. Any suggestions
Jesse, there must be something that is preventing the arm from going down. Can you check? Also try emptying the ice and re-install the container making sure nothing blocks it. sorry not much of a help.
Dec 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Amana Model # ARS9167AB water line works fine, water not filling ice tray and front of fridge between doors is burning hot!! Im afraid to go to bed in case of fire! Underneath is all clean.
Check this Once in a while the temp. in the freezer varies. When the icemaker is running through its' cycle, ice crystals form and cause a blockage and the cycle stops. Also check the stop arm. Make sure it's not stuck in the 'up' position. This sometimes happens when the bin is overly full and the arm gets stuck in the 'off' position. You say you have water supply...other than these quick fixes, I can't think of any other things to check. Good luck.
Oct 15, 2011 | Amana 22.6 cu. ft. Side-By-Side...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Lg side by side model number lrsc23915sw how to turn off ice maker
I'm having trouble identifying that model number, but I can give you the generic answer. On most icemakers the "shut off" is lifting the wire arm to the up position. It should lock in that position. Lifting the arm shuts it off in the same manner that it stops the ice maker when too many cubes are in the tray. I have seen some icemakers that actually have a swich on the front side of them. But, they are in an obvious position so I'm guessing you don't have that style.
Hope this helps
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
Ice maker is not making ice, the arm that indicates if the chest is full won't go down, it is stuck in the up position
It is probably frozen in place. The old ice tray bend and spils water all over the place. Have you changed the ice tray with the update?
Sep 10, 2009 | LG LSC26905TT Side by Side Refrigerator
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
LG LSC26905TT Side by Side Refrigerator Logo
78 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
