Question about GE Washing Machines
The screen is blank on my GE Profile Harmony washer. Serial number AM400360M. I unpluged the washer for 5 minutes with no results.
  • GE Master
  • 5,323 Answers
No power? check terminal block, check push start button, and timer power unit, also a blown fuse may cause a complete shutdown
Posted on Feb 20, 2015
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
fanny
  • 146 Answers
SOURCE: HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Posted on Apr 20, 2009
  • 119 Answers
SOURCE: have a message on GE Profile Harmony washer that
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Posted on Jan 16, 2010
  • 119 Answers
SOURCE: my ge profile harmony washing
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Posted on Aug 04, 2010
GE Harmony profile DPGT750G Touch screen is blank. can you help?
first unplug the unit from power,remove the control panel so as to view the back side of the screen,then where the small ribbon cable enters the screen make sure it is tight,unplug it and re-plug it in straight and securely,if its loose put a small piece of scotch tape on the insulated side of the ribbon cable where it plugs in to tighten fit,dont put it over the copper connections though
May 04, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
My ge profile harmony washer will turn on but will not allow me to start a cycle
try taking apart the control panel and unplugging the main and control board. Wait for 15-20 minutes and replug. Repairman said mine had static in the system and unplugging cleared it.
Jul 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Will not power on
I THINK YOUR TIMER MIGHT BE GONE ON YOUR WASHER. CALL A REPAIRMAN AND EXPLAIN YOUR PROBLEM. HOW OLD IS YOUR WASHER?
May 15, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I need a owners manual.
CALL GE AND REQUEST A OWNERS MAUAL. GIVE THEM YOUR WASHER MODEL NUMBER AND TYPE OF WASHER IT IS. GOOD LUCK.
RODNEY
May 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Feb 28, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Harmony Washer Beeping
first I would to a hard reset unplug washer and dryer for 30 sec then plug back in... also check the wire that connects the washer and dryer ....if this don't wark let me know I can tell you how to get the error codes out of it... let me know
Sep 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Error
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test and setup
let me know what it tell you I can help...
Apr 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
WASHERS WILL START
GE Profile Harmony
3 press HELP
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
