Question about Water Heaters
I have a prothem 100ec boiler fires and temp starts to rise and get between 58 and 60 then for no reason the gas flame increase and boiler over heats and then cuts out when cooled down boiler fires ag
I have a prothem 100ec boiler fires and temp starts to rise and get between 58 and 60 then for no reason the gas flame increase and boiler over heats and then cuts out when cooled down boiler fires again
    Scholar:
  • 94 Answers
It sounds like you have a bad thermocouple. This apparatus senses when the temp is too low and sends an electric signal to turn on the gas to the heater. When it reaches it's preset temperature it sends a electric signal and the gas is turned off. It is best to call a repairman to fix this for a couple of reasons. One, he usually has the thrmocouple with him so you don;t have to wait on a part. Two, you"re messing with gas and if you screw up you can blow up the house and you along with it. Three it is a relatively quick and inexpensive service call, plus if there is anything else wrong he can fix it, save another service call and save you tons on your fuel costs.
Posted on Dec 10, 2014
SOURCE: fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Posted on Dec 01, 2008
tborn6
  • 700 Answers
SOURCE: Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Posted on Jan 11, 2009
  • 150 Answers
SOURCE: alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Posted on Sep 02, 2009
mrhotandcold
  • 248 Answers
SOURCE: Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Posted on Dec 03, 2009
SOURCE: Protherm 100EC boiler not firing up
I have aProtherm 100EC....four plumbers and six days on two kids 5 and 4 and still freezing!!Changed pcb on advice of one and inginition pcb on anothers advice.Fan still wont start and so no ignition and all it was was electric went off for two hrs!!HELP PLEASE it has to be something simple,surely!!
Paul the builder
Posted on Jan 18, 2010
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Why does the pressure rise to over 3bar when the central heating is in operation ?
3 Bar = 43.5 PSI When you heat water it always expands increasing pressure.
In a closed vessel volume can increase by 2-3%. Either expansion tanks allow for this and PSI is maintain or without an expansion outlet the PSI will increase in proportion to heat supplied.
Is this a low temp hydronic boiler operating at or <140F, a hi temp hydronic boiler @ >180F or steam boiler?
Oct 18, 2014 | Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
When my boiler pilot light starts up it kicks out straight way and knocks off the boiler seems to have no faulty parts
Pilot lights have a metal detector just above them, which heats up when the flame is on. If that is not switching fully, Boiler will think no flame and close down. It is a safety feature, but if faulty will stop boiler firing, might just need adjusting, but may also need to be replaced, not really recommended as a diy job
Mar 04, 2013 | Water Heaters
Have protherm 100ec boiler british gas has replaced almost every part boiler will fire temp gauge rises to about 55 flame increase in strenght for about 10sec then boiler cuts out also they keep trying...
Any other symptoms? Is the fault apparent only when drawing hot water? Does the boiler re-light later? Alarm messages? F1? F3 for example?
It may well need a powerflush, but it's best to find out before spending big money with BG.....wish I could get away with charging that much for a flush!!!
FYV
Jan 27, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
When you turn on hot water tap the boiler fires up hot water for a few seconds the water becomes cold the boiler flame goes out then fires up again. when the heating on the flames stays on then off then on...
To avoid having a flame in the absence of water flow, the device you mentioned, 'diaphragm,' detects if adequate water is flowing to avoid a dangerous condition. Check on the housing of it for an adjustment screw; it may have a dot of sealant on it since these normally can be adjusted. It sounds as if it is misjudging the quantity of water flowing through and causing the annoying cycling.
Dec 17, 2010 | Water Heaters
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Gas boiler
hi sounds as though the system is sludged up & needs power flushing.the reason is that the water cannot circulate so over heats & pumps into the header tank.
expect to pay approx 350 400 pounds to have it properly cleansed, it will restore the system efficiency.
The other area worth considering is that it could be a faulty pump os that when th eboiler fires it cannot circulate so in turn expands & vents into the tank.
My advise is to arrange for a corgi engineer to sort it out for you.
Kindly
Richie
Dec 17, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
67 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
