Question about GE Ovens
Do you know how to test the fans on a GE Double Wall Oven (Model # JKP45W0P2WG) to see if they are working? I am wanting to make sure they are working prior to running a self-cleaning cycle. Thanks!
Don't know how to trigger them. Usu. come on during a self clean cycle, but I haven't heard them come on lately, so I want to make sure they are working before I run self-clean cycle again, so I don't blow a control board. Many thanks!
    Scholar:
    New Friend:
  • 123 Answers
Some models the cooling fans come on when you start the oven. In some models the cooling fans comes on only when the control compartment reaches a certain temperature. In this case there is a reverse thermostat. It will close for the fan circuit when it reaches the temperature thus starting the cooling fan.
Posted on Dec 06, 2014
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Posted on May 19, 2008
Krazytech
  • 725 Answers
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    SOURCE: whirlpool rbd275pdb double wall oven died during self clean
    The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
    Posted on Apr 15, 2009
    heatman101
    • 43501 Answers
    SOURCE: GE Electric Double Oven Door Will Not Unlock
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Posted on Sep 30, 2010
    I have a used wall oven. How can I test it before installing to make sure it works?
    call an electrician to wire it on an extension cord .
    Nov 23, 2015 | GE Ovens
    I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
    Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
    Dec 05, 2014 | GE Ovens
    How do I uninstall a GE double wall over?
    The instructions come with the oven. And differ with models. Most important to follow all items. If the instructions are lost , Google GE double wall oven ( give model number). Or try the GE Dealer.
    Aug 23, 2014 | Ovens
    Control board harvesting
    No, the parts aren't the same. The W2BB model has this code for that same part WB27T10283, while the A2BB model has this code for that part WB27T10292. The parts Look exactly the same in the diagrams, however in my past I have discovered the hard way that connectors and things in the circuitry are often different even if they fit. They're pretty pricey too 250 bucks or so...good luck!
    Sep 01, 2012 | GE JTP45 Electric Double Oven
    GE double oven Model JTP56WOA2WW top oven won't heat up, fan runs, relay clicks, no heat
    Hello & Welcome to FixYa
    This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
    Kevin
    Mar 27, 2011 | GE Profile JKP56 Electric Double Oven
    Only bottom of the electric double wall oven works . lts a 1969 G.E.
    If you can, test for power to the element in the top oven. If there is power coming to the element, it could be that the element is bad and can be replaced. If there is now power coming to the top oven there could be a more serious issue in a 40 year old oven
    Nov 30, 2009 | GE JTP27 Electric Double Oven
    GE P7 Wall oven model JK1905AV only gets warm....
    I have a pair I'm trying to get rid of if you're interested.
    Jul 15, 2009 | GE JKP50SH Electric Double Oven
    JTP15 GE Oven - vibration noise
    We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
    Jan 14, 2009 | GE JTP15 Electric Single Oven
    GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    Double 27" oven Model No.911.48489 show F9,later beeping
    The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
    Oct 02, 2007 | GE JTP85 Electric Double Oven
    Ovens Logo
    70 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Oloyede Monsuru
    Are you a GE Oven Expert? Answer questions, earn points and help others
