Question about LG 42LH30 42 in. LCD TV
My LG#42LH30 has a red blue colored stripe down left side
I have only plug in turned on to find issue then removed back and cleaned the T-CON contacts and main board contacts pluged back in no change. Thank you in advance for your professional opinion and advice!! Walter.B
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
  • 131 Answers
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Posted on Dec 16, 2009
  • 8457 Answers
SOURCE: lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Posted on Jan 05, 2010
  • 8457 Answers
SOURCE: LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Posted on Feb 08, 2010
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 09, 2015 | JVC Emerald EM37T 37" 720p LED-LCD TV -...
This is the third time I have posted question. have an LG LCD 42LH30 left side has colored stripes running down the side, I am thinking T-CON board? can some one give me an answer please @ wal5ter1999
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | LG Televison & Video
Have an LG #42LH30 colored stripes down left side static on right
Dec 04, 2014 | LG 42LH30 42 in. LCD TV
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I would like to know the wiring conections for the plug-in on the back of a pioneer deh-2000mp cd player. What color goes where? Thanks
All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Apr 06, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
LG 42LH30 42 in. LCD TV Logo
42 people viewed this question
Computer Repairing
Computer Repairing
