Question about Ovens
F3E3 code is showing on display. Oven got hit by lightning. All lights work including the display screen. Will not allow user to actually turn it on to begin the heating process! Has only been used
Parts that have been replaced so far: 8304051 wiring harness 8186589 Jack probe RA kit 10247024 Igntr-Surf (qty 2) 10134797 Igntr-Surf
SOURCE: oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
Posted on Nov 05, 2007
SOURCE: kenmore oven touch panel error codes f1 f3 f5 f7, oven failure
I had the same problem. It occurred when it was in a cleaning cycling. I fot the F3 Fasult and also the door remained locked. I let it cool down overnight and killed the power at the circuit breaker. I turned the power on and got a F3 alarm and the door remained locked. I took our the screws holding the control panel and pull it out far enough to give me access to the locking mechanisim. I took out the screw holding the locking latch to the motor. With the latch loose, iwas able to get move it out of the door lock. With the door now open I was able to get to the temperature sensor with was held with two sheet mmetal screws. The screw were impossible to get out, so I ground off the heads with a Dremel tool. I couldn't get the sensor wires out. So I pulled the unit out to get at the back sde. I cut the old sensor wires and was able to get in the hole to remove the screws with a pair of needle nose pliers. I installed a new sensor and with wire nuts attached the sensor wires to the computer wires. Make sure that you work the insulation in the hole to plug it back up. Put the oven back in and installed the sensor in the oven with two small sheet metal screws. . refasten the locking latch to the locking latch motor. turn on the power and everything was fine. I ohmmed out the old sensor and it was 180 ohms at room temperature. The replacement checked out at a 1000 ohms in accordance with the schematic for the control. By the way, the schematic was neatly folded on the control panel when I removed it I used a Whirlpool sensor Part No. 12001656 which was half the price of a Kenmore sensor. +
Posted on Oct 24, 2008
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
SOURCE: Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Posted on Sep 29, 2009
  • 194 Answers
SOURCE: My oven codes F3E3
Oven temp sensor failed. It's in the top left corner in the oven. If you have amultitestr you can test it. At room temp the resistance should be somewhere around 1000-1200
Posted on Jan 14, 2010
Error code F3E3 on whirpool self cleaning oven Shut off oven Now only broiler will work. Why
The fault code F3E3 requires replacement of the oven temperature sensor. I suggest you contact www.repairclinic.com for help with repair instructions and the part you need.
Apr 19, 2017 | Ovens
Error code f3e3
Swap the leads on the probe jack terminals at the main board
Sep 27, 2014 | KitchenAid KEBS109BSS 30" Single Wall Oven...
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven has an error displaying F3E3
F3-E3 Cleaning Temp over heat. Replace Sensor
Typical sensor:
Sensor location is usually here:
Whirlpool oven service manual
Jul 21, 2011 | Whirlpool Ovens
My frigidaire oven is displaying F1 on the display case. I had something cooking in the oven and then the breaker popped. I went out to check the breaker box and turned it back on. Now the oven is just...
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement.
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional details.
Hope helps.
Jul 18, 2011 | Frigidaire Ovens
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Electric oven displays F3E3 and beeps
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 04, 2010 | Ovens
My oven codes F3E3.
Jan 14, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
