Question about 3Com OfficeConnect Wireless 108Mbps 11g PoE Access Point IEEE 802.11b/g Wireless Access Point (3CRGPOE10075USFT)
3com router doesnt work at all
When i put the power supply in, the Alert, Power and WLAN lamps are lit. It wont recognize it when i put in a DSL cable or a LAN cable. I can't connect to the router through the wireless card either, it doesnt show up in the list. what do i do?
  • 306 Answers
Re: 3com router doesnt work at all
Contact your ISP for proper settings for the router.
Posted on Nov 11, 2007
0 characters
3 Points
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Wireless Access Points
My D-Link dap-1160 is not working
For routers not just the power light that should be lit. Are you using a modem/router? If so, there should be a DSL,INTERNET,WIRELESS light indicator as well. If the DSL light is OFF,steady red, OFF there might be trouble with your line connection. Call your Internet provider. Also, check cables (yellow cord, gray cord, telephone cord) that should be connected tightly to where it supposed to be connected.
Feb 26, 2013 | D-Link DAP-1160 802.11g Wireless G Open...
My wlan light doesnt come on and thus does not transmit
Replace the Ethernet cable between the DSL/Cable modem and the D-Link. Power-off that modem. Power it on. Power-off the D-Link, and power it on. You should be good to go.
Sep 11, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
I have linksys access point mode; WAP610N , i make the setup wizard and every thing with it cd . If it is connected with my speed touch dsl router its work fine and can browse internet. but when i...
If you look at the lights on it you should have one for WLAN or Wireless connection. If this is not lit up you will need to go into your settings for the router and turn this on, save your settings and come back out again. You can do this by opening a web page and typing in the address bar, or this should let you into your router internal setup, you may need to input a password and security key. Hope this helps
Oct 06, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
3Com 7760 (3CRWE776075US) 802.11a/b/g...
Hi there
I think up to now you've been using someone else's Internet service, by picking up the signal wirelessly. You need your own Internet Service. You now connect your access point in the way the Internet Service Provider guide you. It is a different set up with cable (they provide a modem) or with BT (connection through your phone line).
Dec 31, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
The repeater must be the same brand as the signal it is repeating. Different routers / access points work in slightly different ways and the current generation of wireless repeaters aren't smart enough to work with other brands.
It's kind of like trying to put an engine from a Nissan Altima into a Honda Accord... both make the car move but they aren't the same inside.
Oct 31, 2007 | 3Com OfficeConnect (3CRWE454G75)...
NO IP or MAC displayed
Solution: IP of means your DHCP server is not providing configuration settings to your network card. Reset router/access point by pressing the reset button with your finger, the tip of a pen, or a paper clip for at least 30 seconds. Try again! If this solution doesn't work, try turning off computer, turn off router/AP, and DSL/Cable modem. Turn on devices in reverse order. First power on modem, then router/AP, then computer. Connect to router/AP and see if it provides IP. If this solution doesn't work, your DHCP settings are not configured correctly. See router's manufacturer manual or visit their Web site.
Dec 28, 2005 | 3Com U.S. Robotics Wireless Turbo...
Wireless Access Points Logo
167 people viewed this question
Top 3Com Wireless Access Points Experts
Donna Sander
 C. Dante
C. Dante
Prashant  Sharma
Prashant Sharma
Are you a 3Com Wireless Access Point Expert? Answer questions, earn points and help others
