Question about Whirlpool Ovens
My whirlpool oven keeps resetting itself every few minutes.It doesnt stay on the programme you set.It keeps reverting back to the beginning
I've turned the power off to see if it will reset. It stays on for a short time then reverts back to the beginning
  • 32 Answers
Sounds like bad control board
hopefully still under warranty
Posted on Dec 17, 2014
  • 234 Answers
SOURCE: oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Posted on Jun 28, 2009
SOURCE: power was turned off. I reset the clock to proper
We have the exact same problem. It doesn't heat to above 135. Help!!
Posted on Jan 14, 2010
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Fault with digital programmer clock. Cannot set
Sorry no. you have a defective control panel
Posted on Dec 19, 2010
  • 5370 Answers
SOURCE: Hello, My Fagor 5HA-196 X
Did you tried connecting the oven power cord to any other separate power outlet.Connect oven to the outlet, when only oven is connected and no other appliance is connected.------- The power is getting cut for a second .It can be issue with wall electric outlet.Or the oven is not getting exact power/voltage.Or the over power cord is getting short internally.Or the issue with oven power control board timer.Its cutting off every few seconds and this resets the time.--- If this is the case then board is weak and it has to be replaced.----- First try check in other separate power outlet.If that is not helping then get the over voltage and power outlet voltage checked by the tech.If both checked out ok, then get the over power cord checked by meter.If meter shows drop in voltage, then there is cut in between the over power cord wire.------ But if all power cord wires, the electric wall outlet, the voltage, everything checked ok, then its timer control board issue.It has to be replaced.------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
This should help.Thanks.Helpmech.
Posted on Jun 09, 2011
MY WHIRLPOOL OVEN KEEPS RESETTING A PROGRAMME BY ITSELF EVEN IN MID COOKING. THE OVEN IS ONLY 18 MONTHS OLD. WHIRLPOOL WONT HELP ONLY AT A COST.
Although the manufacturer only give a 12 month guarantee it is down to the retailer to sort faults. Under statutory rights you have up to 5 years to male a complaint. Get a quote for repairs and issue a claim in the small claims court.
Sep 30, 2014 | Whirlpool Ovens
OVEN TRIGGERED THE BREAKER TO GO OFF AND NOW THE OVEN IS NOT WORKING.
First thing is to reset the breaker, it's tripped right now, so turn it on then off again then back on. If it kicks right back off again leave it off as you have a dead short and that can be dangerous especially with an electric oven. In that case call an appliance repair person.
If the breaker stays on after you reset it go back to your oven and see if it has come back on and is working. If it has power but the display is flashing some error code you will need to troubleshoot with the owners manual or look online for a manual.
If the oven is only a few years old it should "reboot" itself when power is restored. Some models require that you manually reset them with some combination of buttons (that's where you need the manual).
I hope this helps.
Jul 30, 2014 | Whirlpool RBD305PD Electric Double Oven
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
140 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
