Blu life one M - how do you remove the back cover?
How to fixtouch screen blu life play phone
New Black Touch Screen Digitizer Glass For Blu Life Play ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.
Rating: 4.2 - ‎6 reviews
BLU Life Play L100A / Play X L102a Screen Protector - GreatShield MERE Mark II Ultra ... About Flashtechllc: The leading provider of cell phone repair parts and ...
Blu Life Play dismounted - YouTube
? 1:55
https://www.youtube.com/watch?v=p_hRhM-bFuE
Mar 10, 2014 - Uploaded by kerdel green
quick amateur video showing how to remove plastic back of blu life play. ... Cell Phone Screen Replacement ...
reparo usb blu life play - YouTube
? 10:54
https://www.youtube.com/watch?v=bblUShTkKlk
Mar 21, 2014 - Uploaded by wayne silva
o video foi feito com um blu life tbm muito boa a camera ... Como fa?o para reparar o conector do meu ...
BLU Life One and BLU Life One XL hands-on: a ... - IT news
hardware_software.complexdoc.ru/1994618.html
Translate this page
Jan 27, 2016 | Blu Life Play Mobile Phone
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
How do I open the back for a sim card
For what phone? Some phones have a slot in the side that is covered.usually beside a pin hole for ejecting.
Most have a small fingernail notch you pry up.
Jan 22, 2016 | Blu Life One X Quad Band Unlocked - 16GB...
How can deactivate the guest mode of blu life pure mobile. its asking me a password to deactivate but i didn't set any password before. in the guest mode i don't have full access for my phone and its...
Okay, here's what you do:
Once the phone is turned on, remove the back cover and remove the battery. DO NOT TURN OFF THE PHONE (Very important), just remove the battery, Leave the battery out for 5 minutes, then put it back in.
Let me know what happened after.....
Dec 28, 2014 | Blu Cell Phones
My blu life view phone wont power on no matter how long I hold the power button and the battery is charged
You might want to try removing the battery for about a minute then put it back in
May 24, 2014 | Blu Cell Phones
Our PS3 60gb, with 4 USB ports is having problems reading the new PS3 games. The old PS2 games still play. When it comes to games like Rachet and Clank or any other new game, it will start then freeze. I...
Hi there, it definitely sounds like the blu ray player. They are relatively simple to fit yourself as long as your warranty has expired. If it is still under warranty just phone Sony and they will replace it.
If you warranty has expired then you can buy a working blu ray drive on ebay for around £60. There is a circuit board that is attached to the blu ray drive, it is extremely important that you keep this as it is paired to your motherboard. Your PS3 will only work with that blu ray circuit board, no others.
To actually replace the drive is pretty easy. On the left hand side of your console there is a warranty sticker covering a little rubber bung. If your system is out of warranty peel back the sticker a little so you can remove the rubber bung. Under this rubber bung there is a small torx head screw, I think a T8 torx but a small flat blade screwdriver will take it out.
After you have removed this screw the whole top of the PS3 slides to the left and comes off. Underneath the PS3 top cover there is another plastic cover with screws all around it. As you are looking from the front of the console there is a marking on the plastic cover that points to one screw that says "S", this is a shorter screw and only goes back in that place. Remove all the screws. Just to the left of the short screw there is a small recess in the plastic casing where you have to push a little black clip back gently while lifting the cover from the back of the PS3. It should all lift forward and come off.
On the right hand side of the PS3 you will now see your blu ray drive. It lifts up but be careful, there is a ribbon cable and power cable attached to it. The ribbon cable is hidden underneath. You have to carefully lift the long black strip that is on the clips where the cable is held. This will release pressure on the ribbon cable and allow you to remove it. You will see the blu ray logic board attached to the back of the drive. Remove this from the drive taking care with a very small connector with a black and red wire, this is the optical sensor wires, remove with care!! Nowafter you have done that you are ready to replace your blu ray :)
Hope this helps and thank you for using FixYa
Aug 29, 2010 | Sony Playstation 3 (PS3) Console
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
Toner life end
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Dec 05, 2008 | Brother IntelliFax-2820 Laser Fax
DVD jammed in player
Hi,,
Ok here is what you do,,
1. Unplug the player
2.) Remove the Top of the player by taking out the screws at the back and sides
3.) With the player opened up look for the disc drive , there should be a cover above it that can be removed by removeing the crews and then lifing it up
4.) with the cover off remove the disc
5.) re-assemble your player.
Nov 01, 2008 | Televison & Video
Removing batterry Cover
when the back cover is removed the hard drive is automatically stopped. that may be the reason why you are not able to access the hard drive.
This is normal, and is advised to always switch off the mobile before removing the back cover. It is not safe for the hard disk, it may crash and affect the life of HD
Apr 18, 2008 | Nokia N91 Cellular Phone
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
