Question about KitchenAid Microwave Ovens
Where can i buy a mounting bracket for my kitchenaid microwave?
  • KitchenAid Master
  • 3,512 Answers
Http://www.searspartsdirect.com/partsdirect/part-model/kitchenaid-parts/all-products-parts/model-kbms1454sss1/0593/0123100/w0806023/00006
Posted on Dec 06, 2014
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
I currently have a non-working over the range microwave, I have bought a replacement. How to I take one down and replace it with the new one?Are the brackets interchangeable?
What brand Microwave are you removing and what brand are you installing? If the are not the same brand they will mount differently. On an older GE you remove the two screws holding the unit in place. They are located on top of the unit on the front. Look in the cabinet above the microwave. After you disconnect the vent pipe the unit slides forward and out. On some other brands the unit will pivot down and then you lift it off a mounting bracket. To make the job as easy as possible and to make sure the vent pipe does not have to be moved, remove the old unit before buying a replacement. Look at how it mounts. Then buy the same brand and it should mount the exact same way, so you could use the old mount. But even then the manufacture may have changed the way it is mounted. I just replaced a GE with a Whirlpool and they mount completely differently. I even had to move the vent pipe 2" to the right. So stick with the same brand and hope they have not change the mount.
Dec 15, 2009 | Microwave Ovens
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
May 23, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Removing a Sharp Carosel R 1440 over the stove microwave
you should be able to do this yourself. Do you have an outlet to plug this into, or will you need to hard wire it into your apartment/house wiring/. If the former, then you should be okay. You will need a bracket/plate to mount the microwave to.
May 26, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
