Question about Microsoft Xbox 360 Console
My xbox 360 wont let me login
Letting it cool down, unplugging it for 20 min
  • 36 Answers
I've done this once, I changed the password for the email that I use for my xbox account and then I forgot I had so when the Xbox asked me to login I kept entering in my old password. If this didn't help you try reseting the password for the email.
Posted on Dec 12, 2014
  • 152 Answers
SOURCE: xbox 360
Open up the console, and clean the DVD Drive lens with some rubbing alcohol and a q-tip. Then put the console back together. If you're uncomfortable with doing that, then either get a friend to do it for you or send the console in to Microsoft for repair.
Posted on Dec 22, 2007
SOURCE: My xbox 360 keeps freezing!!
wrap your 360 in a towel (Completely Covered), turn on the system for about 10 minutes, turn it off, then back on again and and it should work.Although this fix only works fr about three hours it works over and over but the problem you have can also be fixed by replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your 360. But my second solution should only be used if the warranty is void
Posted on Apr 02, 2008
SOURCE: Xbox 360 Keeps Crashing
buy a fan for your xbox 360, if it continues contact microsoft and see if they have a solution, it could be an internal problem that needs repairing, i have the same problem but i am going to get a fan which will cool the 360, and reduce the chance of my 360 breaking
Posted on Dec 29, 2008
cjmeno98
  • 13 Answers
SOURCE: CDs wont read! says "OPEN TRAY"
contact xbox customer support
Posted on Jun 07, 2009
  • 60 Answers
SOURCE: my xbox 360 wont let me accept game invite and
your NAT type is most likely not open. To connect to certain people, you have to have compatible connections.
Posted on May 17, 2010
My xbox 360 gets really hot during gameplay
I went to walmart and bought an external cooling fan for around $20. It is so worth it! otherwise, just take constant breaks every two hors and let the xbox cool down for about ten to twenty mins.
Dec 29, 2010 | Microsoft Xbox 360 Console
One flashing light on xbox 360 and e74 on the tv bought the console used from game stop and this happened
Just Do towel trick
all you have to do is be sure that u that you have the error next take the av cord out the 360 and keep the power in then keep it on then get like 3 towels i just use a towel, a rob, and a bed sheet LOL once u complely coverd the the xbox, keep it on for about a half hour 45 mins. or untill it the xbox gets very hot. once you comformed that its hot, take off the towels or whatever and let the 360 cool down for about 20 mins. or till cool. once thats done plug everything back up and pray to work and its not permentat but enjoy and if happens again do it over
Note: The Sysysten will need to overheat just be in mind of a fire or suthing i dought its going to happen
PS: In this process u will not get the RROD iight
My xbox 360 keeps freezing after a few minutes how can i fix it?
The same thing happened to me and then i got the rrod. :(. But then i did the towel trick and now its works again. the towel trick is where you unplug every thing included the hdd but leave the power cable in. then you wrap the xbox in towels and let it cook for about 20 min. then when its done let it cool for 15 min then it should work again.
Dec 30, 2009 | Microsoft Xbox 360 Console
My xbox wont turn on
just turn it off and unplug everything and let it cool down and then make sure all connections are tight and then try to turn it back on and make sure av cable is plugged in
Jan 07, 2009 | Apple iPod touch
Xbox 360
check the hdtv/tv switch on the xbox side of your AV cable if no try the towel trick toss a towel over it for an hour while it is on then turn in off let cool for 20 min then try again
Aug 15, 2008 | Microsoft Xbox 360 Console
Xbox 360
if you mean the 3 red lights, simple. You will need to have the xbox 360 running, 2 or so towels, and some time. First keep the xbox 360 running, then put the towels over the 360 (make sure to cover the vents). Keep it on for around 20 mins. Then after take off the towels, and let the system cool for another 20 mins. This should let it run for atleast another 2 hours.
Jun 15, 2008 | Microsoft Xbox 360 Console
Help
There are solder issues, so something to try is just leave the xbox on for an hour, turn off let cool for 5 min. If that doesn't work, it's a difficult solution to recommend but the towel trick' does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again. Also don't take apart the xbox, if this doesn't work then just send it back to microsoft
Mar 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 no video but have audio after playing madden
Something to try is just leave the xbox on for an hour, turn off let cool for 5 min. If that doesn't work, it's a difficult solution to recommend but the towel trick' does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jan 03, 2008 | Microsoft Xbox 360 Console
Xbox shuts down during a game 3 red lights
hey johnny you will have to call microsoft and get it fixed there is one thing you can do in the mean time to temp fix it.
what you need is two towels just normal bathroom towels take everything out of your xbox e.g harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about 20 mins then after that take all the towels off turn off the console and leave to cool down for 15 mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you have to do it again. wont fix it but will let u play while microsoft gets it.
hope this helps please rate me
regards grant
Nov 23, 2007 | Microsoft Xbox 360 Console
Sound But No Picture
This Just happened to me. There seems to be a lot of solder issues with the 360. I bit the bullet and tried the towel trick, where you over heat the 360 for about 20 min. I Let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
