Question about Thermador Ovens
Fix a faulty Thermador thermometer that impacts holding a temperature in my oven when Thermador discontinued the part? Part # 622568
Thermador customer service is the worst...they gave no guidance
    Champion:
  • Thermador Expert
  • 323 Answers
It may be a bad connection too. otherwise, check this site for one that might fit . . . http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19145&pID=18668&mode=categorysearch
Posted on Feb 03, 2015
SOURCE: Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
Posted on May 13, 2008
SOURCE: thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Posted on Sep 19, 2009
gripfitter
  • 557 Answers
SOURCE: my oven is hotter than it shows
If you remove the dial you should find an adjustment behind the dial to match it to the temperature.
Posted on Oct 04, 2009
SOURCE: I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Posted on Jan 25, 2010
heatman101
  • 43501 Answers
SOURCE: oven not getting to proper temperature
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
Looking discontinued thermador parts
Refer your problem to an appliance parts distributor
Jun 08, 2013 | Ovens
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
The oven does not cook the food, it only warms the food.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature.
If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired.
If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Feb 10, 2011 | Viking Ovens
I have a thermador oven m#SCD302TP reading F2 F5 // HELP
F2 -Oven temperature too hot
Replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).
Thank You
Sep 03, 2010 | Ovens
Oven temperature does not regulate. The temperature is set for 350 but was 500 degrees in oven according to thermometer. Then sometimes you set it for 350 and it will get to almost 350 and then start...
From the symptons you describe, I would say that the oven thermostat is faulty, and in need of replacement.
Make sure your thermometer is o/k by checking it against another one, or boil some water, and check the temp of the boiling water, this should determine if your thermometer is o/k.
Hope this helps.
Dec 20, 2009 | Kenmore Ovens
Thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
kellythompson@frontiernet.net
Oct 23, 2008 | Thermador Ovens
Ovens Logo
104 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
