Question about Garden
How do I fit the mulcher - Garden
I need a replacement strap for my mulcher.
Fixya does not sell replacement mulcher door straps.
Aug 01, 2016 | Huskee Tractor Replacement Riding Lawn...
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Manuals
You may download the quick-start guide and the owner's manual from http://www.worx.com/en-US/worx_trivac_wg500.aspx
May 30, 2013 | Worx WG500 All-In-One Vac Mulcher Blower,...
21 inch craftsman mulcher mower, if it does not ha...
yes,the magneto on the flywheel will create the energy to make voltage for spark
May 21, 2010 | Garden
Is my Craftsman Mulcher lawnmower a 4 stroke or 2 stroke engine??
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
May 05, 2010 | Craftsman Garden
Can't get spark plug out
if your using a spark plug socket, theres a rubber grommet inside to protect the ceramic plug. sometimes they can be a tight fit to seat properly.
Nov 30, 2008 | Craftsman 4 Cycle Blower/Vac
Sweeper-mulcher starter cord won't move
yes it the locking problem for sure.calling a tech is much advisable.
Nov 09, 2008 | Craftsman Garden
Mulchers safety measures
if you are using a blade mulcher be sure to keep your hands out of it!
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Mulchers storage
when its empty you can store anywhere you like but when its full try and keep in open place due to smell that may burst from the mulcher.
Aug 27, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Garden Logo
539 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
