Question about Camping, Backpacking & Hiking
How do you take a battery out of a model S00G Spotlight?
I took all the screws that were exposed out of the spotlight, but it will not open up to remove the old battery!
    Problem Solver:
  • 15 Answers
Open the rear part there you will see the battery, or maybe the front cover..just explore man.. :D
Posted on Dec 06, 2014
How do I replace the battery in the nose and ear trimmer? Is this even a possibility? Mine is not a spotlight model.
You can, but getting into them is often the problem. They usually have some hidden screws and then locking tags that have to be pressed in just the right place with a plastic tool called a 'bludger'.. Best idea is to find a local service centre and take them in for battery replacement.
I had the battery in a Braun trimmer replaced this way.
Jul 11, 2016 | Wahl Deluxe Spotlight Ear Nose and Brow...
VEC157BDC Spotlight
remove the black rubber guard from the front there is a screw on each side remove them then remove the lens guard then you can get to the bulb. I hope this helps. You will need a phillips screw driver and a flat head one small ones
Jun 14, 2014 | Black and Decker USA Black & Decker...
BATTERIES FOR MODEL JXSL10
Just take battery out and match it with the same type-12 volt sealed lead acid battery-I think mine cost 30$ online. I haven't had luck finding a replacement bulb. That is what my spotlight needs!
Dec 03, 2013 | Jeep Heavy Duty Jxsl10 Rechargeable...
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 13, 2010 | Vector 3 Million Candlepower Rechargeable...
Will not hold a charge...Looking for a replacement battery? Any Ideas?
http://cgi.ebay.com/VECTOR-1-MILLION-CANDLE-POWER-SPOTLIGHT-FLUORESCENT-NEW_W0QQitemZ220469526499QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335501ffe3&_trksid=p3286.c0.m14
Aug 31, 2009 | Vector 1 Million Rechargeable Spotlight
Need adapter for Vector 1 Million sport spotlight Model VEC156. I am unable to find out where to buy an A/C charger/adapter/power cord for this flashlight. Thanks for your help.
if its the one im thinking of, i had the same problem.
if you look at the back and theres the male prongs to plug into the wall
well what i did was i took off the back
then i took off the cradle that held the battery in place, and stood it up on the lens and simply plugged it into the wall to charge it.
its kind of complicated but simple way to save some dough in todays market.
Nov 21, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
87 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
