Question about LG NB3532A 300W Sound Bar Audio System with Wireless Subwoofer & Bluetooth Streaming
Setting up a NB3532A
How do I set up with a Samsung TV?
    Problem Solver:
  • 15 Answers
Check the manual.
Posted on Dec 06, 2014
I have a Samsung TV, half of the screen was vaguely showing, I replaced tcon from eBay, I got more of an image on the screen but not fully, so I replaced the main board again from eBay. When I put that...
distorted screen is it settings are wrong, samsung have a special menu setting you use to set up tv parts. and you have to press them in order on the samsung remote to access the setting. changing parts around will alter the setting, as each board is set up for different model. the setting menu is different from model to model but the boards can be in array of models, do a search for you model and the service mode menu code. and use this to change the settings on the main board to setup tv. its like a bios on a computer.
Feb 01, 2018 | Samsung Televison & Video
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Samsung HLP5067WX No sound from internal speakers
Check ur tv it is not on mute mode.Try go into tv menu go to Audio Seting reset every back to factory setting.Check ur tv Audio Setting is it not on VARIABLE setting.Must be on FIX setting to able to used tv internal speakers.These steps should help tv get audio back.
Aug 08, 2011 | Samsung HLP5067W Television
Hi i have no sound on my samsung LA46M8 tv
Hi... Make sure u choose the TV speaker from the TV settings.
press Menu from your remote control. Settings... then go to TV settings. click TV speakers.
There u can also pick the wireless speakers.
Mar 26, 2011 | Samsung LA46M81BDX 46 in. LCD TV
Best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Nov 09, 2009 | Samsung LE40M91B 40 in. LCD TV
Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Dec 22, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 46in.
This is a Plasma TV set, there is no convergence adjustments on this set. the convergence adjustments are for tube type projection TV sets. You could have a few problems with your TV. You could have a bad color whell assembly, a bad light engine assy. or a problem with the main board. This is not a set a that some who is not trained on plasma TV sets should attempt to troubleshoot and or repair. depending on how old this set is, it may still be under warranty. if it is not, call out only a Samsung authorized servicer, as they will have the boards and proper tools to service this TV. Good Luck
Mar 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
LG NB3532A 300W Sound Bar Audio System with Wireless Subwoofer & Bluetooth Streaming Logo
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
