Question about Necchi Sewing Machines
What could cause the motor to turn but the needle doesnt move?
I push on the peddle to sew, and the motor turns but it doesnt move the needle.
  • Necchi Master
  • 1,860 Answers
It's possible that the sewing machine may need a adjustment or a part could be broken, the machine should be checked
Posted on Dec 06, 2014
  • Necchi Master
  • 12,469 Answers
Make sure the handwheel has not been released as you would to thread a bobbin. Check to see if the center part of the handwheel is tightened. One way releases the handwheel, the other way tightens it.
It's also possible that your machine has not been cleaned and oiled for some time and things are stuck. Get some good sewing machine oil (or even liquid Tri-Flow Synthetic Oil), open the top of the machine and put a couple of drops of oil every place where metal rubs on metal. Also, do the same in the bobbin area.
Posted on May 03, 2015
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 14 Answers
SOURCE: motor works needle does not go up and down
You can call the company toll-free at 1-800-361-4639 and they can tell you what to do. All the phone reps I've talked ot have been wonderful.
Posted on Mar 26, 2009
louislevel_2
  • 374 Answers
SOURCE: kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: when I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Posted on Jun 14, 2009
RickE1
  • 202 Answers
SOURCE: sewing machine no movement
I know what the problem is. Its a cracked gear. When you have the top open look at the big fiber gear on top. It is common for these to crack and now it is stuck. Needs a Bernina service guy to replace it. There is one more smaller fiber gear near the handwheel inside that could be cracked also.
Posted on Aug 29, 2009
WhenI turn the inside nob the needle works but not when I turn the outer nob, it just turns and nothing happens WhenI use the peddle the outernob spins but again the needle doesnt work (nob=handwheel)
On most machines, when the inner wheel is turned counter clockwise, it engages the bobbin winder and disengages the needle movement.
To disengage the bobbin winder and sew, turn the inner wheel clockwise as far as it will go. This should engage the sewing capability and it should work either by hand rotating the large wheel (always counter clockwise!) or with the foot pedal. If it does not, then you most likely need to have your machine serviced.
Jun 29, 2016 | Sewing Machines
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
My Pfaff 130 will not sew when the foot peddle is pressed and the flywheel turns, but the big silver screw in the middle of the flywheel does not move. If I tighten the big silver screw and turn the...
Does the motor turn at all. Does it hum when turning it on. It may be burned or the pulley on the motor is loose. Tighten it up and that should get it . Let me know if that works.
Jan 31, 2013 | Sewing Machines
Nothing works,but engine and belt run
the machine probably needs to be check to see why the needle & bobbin aren't working
May 28, 2012 | Singer 1507
White Classic 312 - I turned on machine, reloaded bobbin and put it back in. Threaded needle, tighted needle arm after threading bobbin and pushed on peddle to start sewing. The machine locked up,...
Bake cookies. This is why you never paid attn when Mom tried to teach you in 1977, and why sewers are on a higher mental plane than yourself, Pammy.
Aug 12, 2011 | White Sewing 312 FS
The needle will not come down and sew when the peddle is pushed or by hand. It feels like something is locked.
First remove the needle and bobbincase.Then try turning the hand wheel.If it turns easily replace the bobbincase and try turning it by hand.If it still turns easily then put in a new needle and try turning it again.Make sure the needle flat portion is on the back side.If it still turns easily it is most likely fixed.Try threading the machine and see if it sews.
Jan 28, 2011 | Brother Sewing Machines
The needle is not moving when I push the peddle Its making the noise but nothing on top is moving
it sound as if the belt from the motor to the handwheel has come off you will have to have put back on or take it apart and put it back on yourself
Aug 27, 2010 | Singer 118 Mechanical Sewing Machine
Needle catching / getting stuck
You probably just need to clean the bobbin case and the foot area of lint and debris. Other things to check: is your bobbin loaded correctly? is your needle in correctly? is the thread loaded correctly. I've found these to be the cause of most problems I've had in 30 years of sewing.
Aug 29, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
113 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
