Question about Garrity Camping, Backpacking & Hiking
How do i get the battery out of my Garrity S800G spotlight
Attempted to take screws out to open battery compartment
3 Suggested Answers
  • 973 Answers
SOURCE: replacement 6v charger for Garrity spotlight
Contact Garrity at http://www.garritylites.com/contactus.html
Posted on May 25, 2010
  • 15 Answers
SOURCE: How do you take a battery out of a model S00G Spotlight?
open the rear part there you will see the battery, or maybe the front cover..just explore man.. :D
Posted on Dec 06, 2014
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
Dec 06, 2014 | Camping, Backpacking & Hiking
Battery for spot liteS800G
Most likely has been charged as many times as possible. Time to replace the battery.
Jul 15, 2014 | Garrity Camping, Backpacking & Hiking
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
How do I put the battery into my new ibeam floating lantern?
This is an absurd situation. I am returning the flashlight for a refund.
Will never buy Garrity again.
Dec 24, 2009 | Garrity Camping, Backpacking & Hiking
How do you change the AA battery's for a Garrity Aluminum Flashlight?
If its the one I have ... A battery may have failed and leaked causing it and the battery unit to become stuck. I pulled off the top of mine and pulled out the LED assembly and banged it on the bench a few times and it popped out and I cleaned it up with some baking soda and water.
Sep 19, 2009 | Garrity Led Rch Flashlight
Camping, Backpacking & Hiking Logo
106 people viewed this question
Top Garrity Camping, Backpacking & Hiking Experts
Tom Queen
Tom Queen
aron5566
aron5566
tjcwriter
tjcwriter
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
