Question about Boating
1984 35 hp evinrude will not turn over or starter motor wont engage
Pulled starter motor a part to check bushes and clean out black soot checked all wiring as what i can is fine
    Sergeant:
  • 456 Answers
Check fuse
Posted on Dec 07, 2014
  • philipp noble Dec 07, 2014
    All good worked out what is was the solenoid was buggard
Starter motor wont engage ?
Check by getting a screwdriver and bridging the terminals on starter if it doesn't turn try couole o wacks I know sounds funny but does actualy engage the pin
Mar 06, 2015 | Ford Cars & Trucks
Hi have a 1984 evinrude 35 hp model no E35RLCRR that wont start
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
Dec 23, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Hi i have a 1984 35 hp evinrude electric start E35RLCRR that wont start or turn over
If you are sure that all connections are clean and bright, including the battery to the ground and battery cable to the solenoid, jumper from the battery (+) to the solenoid (+). If the solenoid clicks, but motor doesn't turn over, your solenoid is bad. Try jumpering momentarily from the battery (+) to the starter (+) and that should cause the starter to rotate. If that makes your starter rotate, your solenoid is still bad. Be sure that your starter has a good ground connection
Dec 23, 2014 | Cars & Trucks
2000 gmc jimmy 4x4 p0300. Replaced cap, rotor, wires, plugs, map sensor, checked icm. Nothing has helped
Just a thought,pull the dist.cap and make sure the rotor has
no side to side play ,thinking maybe a bad upper bushing in
the dist.Also,if the EGR valve has carbon and soot built up
on the piston it will make it idle really poor ,but run ok.
Might pull the EGR and clean it with intake cleaner.
Hope this helps.
Apr 12, 2013 | 2000 GMC Jimmy
Starter motor wont work evinrude 50hp 2cyl
Sometimes there is a switch which prevents the starter from working in gear. This switch could be out of adjustment. Otherwise you need to check for a bad relay by jumping the one you can find and seeing if the starter will turn. Check the grounding on the motor too.
Feb 01, 2012 | Boating
Starter drive gear wont engage on a HD fxrs
Sounds to me like the "overrunning clutch" is bad. You'll have to remove the starter and disassemble it. The starter drive is part #31663-90 according to the latest V-Twin book I have. It may have a different number on your 2000 model.
Sep 02, 2009 | 2000 Harley Davidson FLSTC Heritage...
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
May 06, 2009 | Boating
Boating Logo
57 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
