Hey would u know the reason why my dell lattitude e54330 won't turn on the screen is black and all I hear is the fan. My computer also said something about critical process died
    Problem Solver:
  • 9 Answers
Sounds like the video chip is dead.
Posted on Dec 06, 2014
durtopian
  • 408 Answers
SOURCE: my computer screen wont turn on the power is on
Sounds like either the ram may be bad or the video card is bad.Plug in an external monitor and see if it shows.If it does that will eliminate the video card being bad.If it does'nt show, the video card is most likely bad.A bad ram stick can cause it also.You could make sure the display is plugged in securely on the motherboard too.Good luck!
Posted on Aug 17, 2009
drifterK
  • 4924 Answers
SOURCE: how do you solve blue screen stop 7b in lattitude
blue screen errors are usually from a malfunction of the ram memory ...an fatal error of the system ...or a change of hardware without re-installation ...so ..if you know that your system its intact and has to work ...usually re-installation of the operating system ...I mean a brand new one ...not repair or upgrade...but one with formatting C partition ...will fix this problem ...also restore bios settings to the factory optimal defaults
Posted on Sep 05, 2009
  • 16 Answers
SOURCE: My laptop screen won't turn on
Hold down the power button until the light by the card reader goes out, swap DVD drives to install Vista (burnt copy anyway), install YouCam for webcam to work, Quickplay for remote control... Hope this helps someone as I had a hard time finding good information regarding this and it is hugely common for these machines. HP replaces different components for different customers and charges plenty for it if your serial # is not within range for free service... I just bought one for $100 that the "motherboard was fried" and had it working perfectly within hours (restarting right away so that I could then work with it) Have had many offers of as much as $350 already for it and wouldn't sell.
Posted on Feb 27, 2010
  • 12 Answers
SOURCE: My Dell Latitude D620 Screen is Black and the
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
Posted on May 15, 2010
  • 6 Answers
SOURCE: when I turn on my dell inspiron 1526 the screen
Try plugging a monitor into the VGA port on the back. If that works, then it's your LCD screen. If it doesn't then it's most likely your video card or your motherboard.
Posted on Aug 19, 2010
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell inspiron D610 fan wont turn on
New cpu heatsinks use water in sealed tubing, and can cool for a long while. Idling computer may not need more cooling.
Mar 15, 2012 | Dell Lattitude D610
My Dell Lattitude e6400 won't turn on. After pressing the power button, the fan turns on for a few seconds and then turns off. Immediately after, the blue buttons at the top start to blink. What...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 28, 2011 | Computers & Internet
Plugged it in to a wall outlet, turned on the computer, the microsoft screen scene appeared, the jingle played, then it turned itself off and won't turn back on.
Unassemble the battery and after 5 minutes reassemble it, then plug it in another wall outlet and when the charging light turn on, turn on the notebook.
Jul 21, 2011 | Dell Lattitude D610
How do you solve blue screen stop 7b in lattitude
Sep 05, 2009 | Computers & Internet
How much is a dead dell inspiron worth?????
I saw used adaptors go from 20 -35 dollars. Not knowing if screen and hdd are any good I wouldn't give more then 25 dollars
Jan 02, 2009 | Dell Inspiron 1100 Notebook
Dell Lattitude d630, freeezing issue
Had same problem -- changed motherboard and fan on video card -- for this laptop problem occurred twice about a year about -- suspect fan on video card was causing overheat
Dec 12, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
It turns on and shows the BIOS screen? Can you access via F2? If it shuts down, check the RAM and RAM slots! Wrong CPU can also imitate a dead machine
Dec 07, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
INTEL PENTIUM DUAL CORE PROCESSOR
I would buy a can of compressed air and see if cleaning out some dust will get the fan blowing the way it should. It definitely sounds like it is overheating and cleaning out the dust may be the most cost effective way to start. Let me know how you make out.
Chris
May 28, 2008 | Dell Inspiron E1505 Notebook
Screen goes black but computer is on
I would turn the computer off at night, but try to restart the computer. the computer can get stuck in a suspended state of "hibernation" and due to a program error or a corrupt file it can get stalled this way ( just like when your computer freezes)
Dec 29, 2007 | Dell Dimension 2300 PC Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
