Question about Brother ML-100 Typewriter
How does the print head on a Brother ML-100 sense when it has reached the left hand side after a carriage return?
I am working on a project that uses the print head from this ML-100 typewriter, and I would like to understand how the position sensing works. I have removed the print head and examined it closely, but without tearing it apart, I am having trouble understanding how the sensing works. I have tried finding a service manual online, but so far no luck. Thanks for reading this!
  • 455 Answers
When the print head reaches the left side it touches a switch to cause it to inter the setup for the print wheel and ribbon mechanism
Posted on Dec 06, 2014
Testimonial: "Thanks for the quick reply. I see a small cone-like thing on the left side of the carriage area intrudes into the print mechanism as the print head moves to the left. This pushes a white lever of some sort, but it doesn't seem to do anything, and I don't see any microswitch (yet), nor do I see how it sends that position information back via the wiring to the control circuit board. Any additional clues? Thanks again :-)"
  • James Cagle
    James Cagle Dec 09, 2014
    it gets a signal to the control board thru the carrier wiring harnes
  • Corey
    Corey Feb 21, 2015
    Thanks for the reply, but this isn't anywhere near specific enough. There are three sets of wires in the harness in total, and none of these lead to any kind of sensor in the print mechanism. One set is used for the stepper motor that moves the print mechanism down the paper via a rack and pinion system. A second stepper motor is used to select the letter on the daisywheel, and a final pair of wires is used drive a DC motor that has multiple purposes.
I am working on a little project to use the print mechanism from a brother typewriter (ML-100). Unfortunately, I have been unable to find service manuals anywhere for this typewriter. My current q
I found a small piece of plastic caught under neath the carriage
of my Brother GX-6750 Electronic Typewriter. The piece looks as if it slipped onto some type of small end cylindrical peg one sixteenth long and one thirty-seconds in diameter. The piece has a lip where it latches on to something and the other end is flat with a tiny edged lip. The middle piece is where some peg goes into it and the piece is one piece. The carriage works improperly and fails to type. The hammer mechanism won't move forward on it's pivot to punch the daisy wheel. When the keys get punched, nothing happens. I just bought the GX-6750
through ebay and it arrived that way today. I'm looking for suggestions to get it fully operable.
Dec 06, 2014 | Brother ML-100 Typewriter
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How do i release the left and right margin
Move the carriage (print head) to the margin you would like to clear. When you hear the beep, hold down the [ALT] key and press [6]. Now use the backspace or the space bar to move the carriage to where you want the margin set. Now hold down [ALT] and press [7] to set the left or [8] to set the right margin.
Dec 06, 2010 | Brother ML-100 Typewriter
Brother MFC 240c error 30 after printer jam.
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Dec 08, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to print 30
  8. Press 2 (No).
Nov 22, 2009 | Brother MFC-845CW InkJet Printer
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Print Unable 30 Error...
  8. Press 2 (No).
Jun 12, 2009 | Brother Multi-Function Center MFC-240C...
Was the carriage return ever on the right?
I have worked on typewriters fo 20+ years.
The only typ's I know of that had the return on the right hand side are all the manual typ's
Feb 19, 2009 | Brother ML-500 Typewriter
Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Brother ML-100 Typewriter Logo
95 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
