Question about Garden
19,2 sprayer will not spray trickles out hear and there
Motor runs cleaned out wand and hose still nothing
jj505
  • 195 Answers
SOURCE: fimco atv sprayer troubleshooting
Are tips clogged??
Posted on Mar 31, 2009
radar001
  • 1051 Answers
SOURCE: Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Posted on Mar 24, 2010
  • 11800 Answers
SOURCE: MY 16 GAL. UNIT WITH
This is an extremely simple unit: an electromechanical pump - diaphragm model(an electromagnet with an internally attached switch) 12 volts powered, a safety pressure switch that cuts the power to the pump when the pressure in the tank reaches 70psi and a power cable.
If you can hear the pump run then either the diaphragm made out of a rubbery canvas) has failed or the tank is not sealed so the pressure generated by the pump is lost. To find out which just take out the pump from the top of the tank and see if it pumps air: if it doesn't then you will need to replace the diaphragm, if it does find and fix the leak in the tank.
Posted on Jun 10, 2011
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
SOURCE: Ortho 2 gallon pressure sprayer has pressure but no spray
I had the same problem and had to take apart the handle portion and found that there was something in the line at that point. After cleaning it I had the same pressurse as when it was new.
Posted on Mar 24, 2012
Roundup battery propelled sprayer not working
Fix for electric spray wand not working that worked for me. Yes my wand would only spit out some foam, and nothing appeared to be clogged. The wand would spray just fine when I placed the siphon tube into a bucket of water.
Apparently what was happening was that the wand pump was creating a partial vacuum in the air tight canister, causing the electric pump to stop pumping. After all the battery pump is not all that powerful, just got a little foam. So I unscrewed the cap about one turn allowing replacement air into the canister and the wand started working.
Apr 06, 2013 | Garden
Washer fluid not spraying out onto windows
when you push the button to spray the window "do you hear the sprayer pump motor"?
If no, your sprayer pump motor could have failed or come diconnected. now if you do hear the sprayer pump kick in then> check your lines "the small rubber hoses that lead to the actual sprayer nossels. make sure the small hoses are not damaged and leaking and not pinched or restricked.. in rare cases the sprayer pump could have failed and still make a sound like its working but not pump out any fluid.. also in some cases BUT RARE you could have a line or filter screen plugged inside the washer resivor.. Good Luck!
Sep 13, 2011 | 2003 Chrysler Voyager
I can not get anything out of the lines, just avery small trickle
disconnect the wand at the base wghere it meets the pistol, pull trigger and allow to flow out, reconnet and. also, unscrew end nozzle and rinse out and pull trigger to clear wand too.
Aug 12, 2011 | Cepia One Touch Pistol Motorized Power...
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
Need replacement part for 16-gal sprayer. It's the part that connects the hose to the gun -- hose end is broken off. What is this called and where can I get one?
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Jun 02, 2010 | Northstar Garden
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Mar 23, 2010 | Rl Flomaster Acid-Resistant Sprayer...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Clogged and can't get the weed killer to pass through the power wand
EASY FIX!
Hold the sprayer lower than the tank and run it until it sprays. You're done. They seem to lose prime, it usually happens to me when I run it completely out and/or first use (almost year round for us). Mine works fine every time I do this.
If that doesn't work, check the filter on the end of the hose in the tank, blow compressed air through it - NOT BY MOUTH!! Also check for any leaks/pinholes/kinks in the hose - they will **** air instead of solution!
I've had mine for 3 seasons in Phoenix and love it! I've n never had any of the other problems I listed personally. Handle the liquids like you handle gas for your lawn mower, etc:
1) Don't let any dirt to get in the solution.
2) Wash the system before storage ESPECIALLY AT END OF SEASON by spraying clean water through It for a couple of minutes or so and rinsing the tank. STORE INSIDE FOR THE WINTER if it freezes, it may trash it. Leaving anything stronger than Roundup (TM) in it for more than a week or so may eventually damage the plastics and/or seize the pump too.
Apr 30, 2009 | Cepia "" Hands Free Power Sprayer
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
