Question about LG WD-1070QDP 7 Kg Direct Drive Washer
My LG Washing machine is not spinning. It also comes up with OE. Can you help
I've cleaned the hose & filter. The filter is loose.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The most common problem with spinning on this model machine is the tub bearing. Normally it would be very noisy when it did spin.
Massive job to replace it.
Posted on Jan 04, 2015
I"m getting the OE signal.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 12, 2011 | LG WM2277H Front Load Washer
I,ve a LG VM-1433IFD model and I,ve had it unblocked and now its coming up on screen as OE fault help
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.
Causes
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system.
Thank You
Sep 08, 2010 | Washing Machines
Help!! the washing machine wont spin out it keeps commin up wiv oe?? plz help
OE means that the drain filter or hose is blocked or kinked or clogged.
Clean and straighten the hose and clean filter.
Good luck
Feb 08, 2010 | LG WD-16115FD Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
My lg intellowasher wd1290 error code OE
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
WATER WILL NOT DRAIN OR SPIN
OE is inded a drainage error.
From what you describe it is most likely that the drain motor is not working properly due to a loose electrical connection or bad motor itself. This is not that easy to verify since it requires some machine moving and disassembly to get at it.
I can give you further instructions if you like...
If your machine is still under warranty you should call someone in for service.
Aug 06, 2008 | LG WM1815CS Front Load Washer
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
LG WD-1070QDP 7 Kg Direct Drive Washer Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
