Question about Western Digital Computers & Internet
Western Digital Hard Drive WD2500B015 getting power but will not turn on...Suggestions?
Power Adapter providing correct 12vdc but drive will not turn on when on/off button pressed.
    Problem Solver:
  • 9 Answers
Buy a new external hd enclosure and reuse the hd from the failed enclosure. Hard drive enclosers are cheap BTW. Try newegg!
Posted on Dec 06, 2014
750gb
3.5drives require 12vdc at no less than 2 amp recomended 12vdc 3amp it is always best to provide more amp for hard drive keep the voltage correct 12vdc
asme adaptors work out to 4 gig drives all my Western digital drive have same power adaptor no matter the Gig size .
May 05, 2014 | Maxtor Hard Drive
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
I have a Western Digital My Book Essential Edition 160 GB hard drive. Power and light comes on. Hard drive tries to read, clicks 4 times and turns off (light stays on). Repeats above 3 more times and...
Your drive is most certainly dead.
Any unusual sound from inside the drive is not good.
The light is only an indication power is supplied to case.
You could check to see the power supply is providing the correct 12V but it probably is.
Also you could try to connect the drive in another machine, or in an empty case.
If you have another drive that plugs into the case, you could try it to test the case.
I suspect that you will be buying a replacement unit, or at least a new drive for the case.
Feb 11, 2011 | Western Digital My Book Essential Edition...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Need power supply spec's for this WD25001032 hard
If you can procure it you need a "Wattac" AC adapter
model: BAO362ZI-8-A01 (made in China)
Otherwise you need a 12 volt 2 Amp. power pack with positive on centre contact & 2mm pin hole.
Mar 26, 2010 | Western Digital 250GB MyBook External USB...
My ac adapter green light turn off when i turned on the hard drive
Chances are you have a faulty power supply. Contact Western Digital at their website for an RMA. The website is
http://support.wdc.com/warranty/index.asp?wdc_lang=en
Sep 02, 2009 | Western Digital Elements powered by WD 320...
No power on WDelements WD5000
It's not a new hard drive casing that you need, rr_atl, it's a replacement power supply. Western Digital is well know for selling very poorly manufactured power supplies with this hard drive series. The problem you described is a bad power brick.
Jul 31, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Computers & Internet Logo
152 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
