Question about Garden
My Homelight 26b MightyLite leaf blower is so hard to pull start I have to put my foot on it to steady it. I pulled the spark plug and now it pulls so easily I can pull the start just holding the uni
I pulled the spark plug and the pull start is so easy. Put the plug back in and have to stand on the unit to steady it when pulling the start cable and it still is hard to pull
  • 24 Answers
Joe,
Compression is what makes it hard to pull start.
It should be like that.
Try holding the Draw/Pull Cord tight to your stomach and push the Blower away from you.
Kind of like throwing the blower down & away, but holding on to it.
That might be easier than pulling the cord and will save your arm.
Good luck !
Posted on Dec 09, 2014
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Posted on Nov 29, 2008
  • 398 Answers
SOURCE: Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Posted on May 17, 2009
  • 2239 Answers
SOURCE: Husqvarna blower #125BT won't fire over, has spark.
I have seen some issues with these machines shearing the flywheel key ( it is an alloy key part of the flywheel ) if the key has sheared it will knock the timing out and will now require a new flywheel.
Posted on Jul 08, 2012
My homelite 26b blower caught fire when checking for spark what's wrong
when you pulled the start cord, gasoline vapors were ignited when you put the spark plug too close to the fuel source.
Sep 01, 2015 | Homelite Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Homelite 26 BV Gas Leaf Blower
sounds like you had fuel leak into the cylinder over the winter. The liquid in the cylinder is what made it so hard to pull that first time, as it won't compress like air. What you do, is take the spark plug out, pull the starting rope several times, dry off the spark plug, and let both sit(plug out of the cylinder.) for a couple of hours. Then put the plug back in, put the wire back on it, put it on full choke, and pull until it hits once. Then put it on half choke, and pull til it starts.
Mar 28, 2010 | Homelite Consumer Products 7 Amp...
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My homelite might lite 26b will run in the choke position but cuts off in the run position. I have drained the gas and put in fresh gas, new plug and opened the carburetor and cleaned it.
if it seems low on power,remove the muffler and clean out all carbon build-up,if it has power as in full throttle,then the carb is still dirty and needs to be rebuilt
Mar 12, 2010 | Homelite Consumer Products MightyLite...
Starter rope hard to pull
Usually these motors get tough to pull through when there's moisture (water) somewhere in the fuel system.
Fuel compresses, but water won't and when you pull a bit of water in the cylinder it will buck back on you.
Best bet is to drain the carb, fuel lines, and tank and put all fresh fuel/oil in. you can also pull the spark plug and pull the motor through with the plug out to dry the cylinder...
Oct 31, 2009 | Homelite 'Yard Broom' Leaf Blower
HB-180 Leaf blower won't start
if its flooded then it surly wont fire,not a 2-stroke. are you over priming or is there a malfunction. remove plug,put plug not a tester in the end of lead,ground, and pull. spark should be purple and consistent. if red/yellow/intermitent. change he plug. if the engine is only flodding on its own then the needle and seat could be stuck open in the carb, gas tank vent in fuel cap plugged and building tank pressure, or fuel mixed too rich. let me know what you find
Sep 02, 2009 | Homelite Consumer Products MightyLite...
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Diesel fuel in homelite leaf blower !
this is not a problem
you need to remove all the fuel
and remove your spark plug add new fuel and with the spark plug out pull it over many times to purge the system now install a new spark plug and you will be fine
Nov 25, 2008 | Homelite Consumer Products MightyLite...
Craftsman 2cyl leaf blower wii not start
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
