Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Hi, i have a water heater (Rheem XG50T...) w/ a wifi module. Today, the temp / pressure relief valve drained a little bit and now my water heater does not work as the error A102 does not get clear eve
Dried up everything (sensor as well). Can't get the water heater to start again (it won't as long as the error A102) is on. What can I do?
  • Yanick Imhof
    Yanick Imhof Dec 06, 2014
    Exact model is: XG50T12DM40U0
  • Rheem Master
  • 5,089 Answers
Error A102 ?
Where does the error code show on your model?
The XG50T appears to have honeywell gas control valve that flashes error code with series of blinks, and not LCD readout.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If the release of water got electronics wet, then the electronic parts likely will not function.
Release of water from TP valve means temperature of water inside tank exceeded the temperature-pressure rating of TP valve.
This is a safety feature.
Water from TP can indicate thermostat failure, or other less serious issues.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Your water heater appears to have 9 year warranty.
Serial number located on label on side of tank will have numbers- 1st and 2nd digits are week of manufacture, 3rd and 4th digits are year of manufacture,
Call Rheem since they do not post service manuals.
Other companies post service manuals and are much easier for DIYers.
Gene
Water Heater Timers Save Money
Posted on Dec 06, 2014
  • 4 more comments
  • Yanick Imhof
    Hi Gene, I can read the error from my iPhone (via the wifi module). I am not really sure what somehow it got stuck with this error...
  • Yanick Imhof
    Anyway, thanks for the useful link and detailed explanation. I am going to check it out a few more time. Raheem support should come by tomorrow. Thank you
  • Gene Haynes Dec 06, 2014
    Wow... email eror c odes are new to me... I want to know more about this advancement,,, but Rheem simply does not post DIY resources for the homeonwer or the repair/website and forum guys like me.
    I meant wi-fi error codes/ not email. I sure wish I had the full product manual for that system... send any resources you get from Rheem so we can hone our skills at helping other folks
  • Yanick Imhof
    Yanick Imhof Dec 07, 2014
    Rheem came yesterday and it appeared that the main PRV was effective. This has been replaced but the error is still showing up on the mobile app. I'll try to return the wifi module to Home depot and see what they say.
  • Gene Haynes Dec 07, 2014
    PRV or pressure reducing valve is needed if household water pressure exceeds 80 psi. This is to protect the tank and household plumbing from damage caused by excessive pressure on water line. PRV can cause a 'closed system' where the hot water inside tank cannot expand. The pressure inside tank builds up and the TP valve releases water. Usually if you have a PRV, it is recommended that you install expansion tank on the cold water line, between PRV and water heater tank. Otherwise, I could not find any resource for the error code displayed. Rheem does not post service manuals... and this causes customers to call for service technician... which is good for Rheem's profit, but not always best for customer. Other water heater manufacturers post service manuals.
Water heater relief valve tightened up over wiring???
You can turn off water and add a few layers of teflon tape to snug it up a bit. You should also run a pipe down to 9" from the floor. that will remove any danger to the wires
Jun 09, 2014 | Rheem Water Heater Pressure Relief Valve
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Water boiling out of the pressure relief valve
1) Copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Problem indicates bad gas control valve thermostat.
The dial located on gas control, is part of the thermostat on gas water heater. Copper probe protrudes into water heater, and this probe contains the ECO energy cut off and thermostat. Thermostats get out of calibration, or they fail. Replacement should be done by experienced person, otherwise it is relatively simple using pdf link above.
Feb 17, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water dripping out of drain line on my Rheem Water Heater
The T & P valve is connected to the drain and it may be bad causing it to drip. You could try lifting the lever and then closing it back on it to see if it will seal. Also check the thermostat for heat setting, but than likely it is going bad.
It is a pressure relief valve and normally last about 5 years or more before they need to be replaced. The purpose of this valve is to protect heater from building up pressure and protecting the home, It releases water once the heater reachs beyond the limit of the valve can handle.
It is a standard 3/4" thread and can be removed with a pipe wrench. Just turn power, water off and drain water down to just below where the drain is.
Lowes or Home depot shoul dhave one just ask for a pressure relief vakve for a Hot Water Heater. prices range around $15.00.
May 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gas water heater is discharging out the pressure relief valve? what problems do i have?
The water heater is over heating the water, possibly boiling it and causing steam pressure build up. The thermostat is not sensing the temp to shut off the flame. It would be wise to either have a repairman come out or replace the heater. If pressure builds too high and the relief valve cand keep up ,theer could be a rupure of a water lineSoooooooooooo, turn the gas off and git er done.
Nov 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
May 24, 2009 | Water Heaters
Pressure valve releases sometimes , I lose a good bit of water. When i tap the valve handle, it shuts off.
The pressure release valve is a safety feature. If it is leaking alot, it could be that the valve needs to be replaced or it could be that the high temp. shutoff in the hot water tank is malfunctioning.
Apr 20, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The pilot was out this morning and after I got it started, I got
Hi jeake9,
Yes, you are correct it sounds like the pressure relief valve. It is an important safety device that lets water out of the water heater when temp/pressure exceed the limit set on the valve. It did its job good.
Now the important part is to change out the valve and try to diagnose why it tripped. Odds are the water temperature was too hot AND the relief valve couldn't close because of mineral deposit build up.
Replace the relief valve and turn the water heater down for starters.
Please rate this response and Good Luck, Phil
Jan 01, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
485 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
