Question about Kenmore Washing Machines
How do I get my kenmore 111, Model 22622100 to drain and spin
Kenmore 111, Model 22622100 Won't wpin or drain and makes a weezing sound.
Your pump or the filter is blocked up
something wrong with the drain to waiste ... side
Posted on Dec 09, 2014
GodBlessU
  • 3513 Answers
SOURCE: 22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Posted on Aug 30, 2009
  • 240 Answers
SOURCE: Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Posted on Mar 14, 2009
jsrock516
  • 5911 Answers
SOURCE: My Kenmore washer 22622100 is broken - the washer
The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Posted on Jul 26, 2009
SOURCE: Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer making humming sound and won't agitate
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kenmore 24932 Top Load Washer
Washer will drain but won't spin
check your lid switch, make sure it is open and close properly..you have very strange problem never run in one like that...for more info please contact me directly at totalcarefl@yahoo.com
Sep 07, 2009 | Kenmore Washing Machines
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22622100
Check your drain hose an make sure it is not touching water. If it is hard to tell fill it and put it in spin. Then pull the hose out until you hear the water.Then zip tied the hose so it will not move.
Aug 03, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
148 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
