Question about Freezers
My freezer won't get below four degrees. What can I do
Nothing just fast freeze
    Sergeant:
  • 236 Answers
It sounds like the coolant is not circulating properly or the compressor is faulty. See if you can get access to the back of the freezer and touch the compressor motor but be careful. If it is very hot I would think it is one of the above and a service engineer needs to be called.
Posted on Dec 10, 2014
3 Suggested Answers
  • 288 Answers
SOURCE: The 2 fans are not working but the freezer coils
the freezing is and temp are caused by the fans not working. One fan pulls warm air out of the box and across the evaporator coil, which in your case is frozen, and the other fan is used to pull air over the condensing coil which rejects the heat pulled out of the box. check the wiring diagram for a fan relay first, which can easily be changed out, or by some crazy chance, both fans quite working at the same time
Posted on Nov 27, 2009
caroldon
  • 17130 Answers
SOURCE: Freezer won't get below 30
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Posted on Aug 24, 2011
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
Freezer stuck on fast freeze
i think ,you are right ,friend.
Feb 19, 2013 | Freezers
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Aug 24, 2011 | Kelvinator Freezers
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
78 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
