Question about Bose SoundLink Air digital music system with Apple AirPlay
Bose soundtouch20. Wifi is ok. All was working well. Now, I chat get the music on the bose. Trie disconnecting and on again but won't work
Disconnecting, and on again
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Posted on May 03, 2009
cjackHD
  • 71 Answers
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
Posted on Jun 01, 2009
cjackHD
  • 71 Answers
SOURCE: bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Posted on Jun 21, 2009
How do I make a playlist
I didn't see anything about making playlists in the manual but this is a link to the manual from the site.
http://worldwide.bose.com/library/assets/pdf/guides/soundtouch20/soundtouch20_eng.pdf
Aug 14, 2014 | BoseĀ® CORPORATION Bose - SoundTouch 20...
Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
Apr 06, 2013 | Bose SoundLink Wireless Music System...
Bose sa3 amp, blew a fuse in it, replaced it and now it won't power up. Nice little amp, would like to find out how to test out what is wrong and fix it
If you can,check with your multimeter to see if the two voltage rectifiers are good.If they are OK,you may need to replace the 2 audio amplifiers.This will require proper tools and good experience.
Jan 06, 2013 | Bose SA3
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
Is there any way to hook up a sonos zp120 to the bose 901's without using an amp
No speakers will run without an amp.
The Active Equalizer must be somehere in the Line Level path between any source and whatever amp is exclusively driving Bose 901's, which makes the ZP120 useless as a networked music delivery system becuase everything IT outputs would be 901-encoded - unless you had 901's in every room.
The Sonos neither knows nor cares what processes are applied to the signal before it arrives through the Line Level inputs but the digital audio/ethernet route lacks anywhere to insert ANY analog processing, so 901's will not work with the ZP120 if the music originates elsewhere.
I'm not so sure how the claimed 55 watts would work out for 901's. I'd take that specification with huge grain of salt as this unit only weighs about 5 lbs.
This link leads to the multi-lingual manual...
http://www.google.com/url?sa=t&source=web&cd=8&sqi=2&ved=0CF4QFjAH&url=http%3A%2F%2Fwww.abt.com%2Fdocuments%2F20166%2FZP120_Setup_Guide.pdf&rct=j&q=sonos%20zp120%20manual&ei=nwV7TpjcLumIsgKfm7WzDQ&usg=AFQjCNEp4MtETHn2IZLqk9fVXn4QPsV9iQ
Sep 21, 2011 | Bose Audio Players & Recorders
The CD won't spin
there are lens cleaner cds with liquid cleaner. get that kit & run this cd with cleaner on its brushes. if still not working unplug the system & open the cover & see there is lens on cd drive unit. clean upper surface gently with soft cloth. if not working then replace the cd drive mechanism.
Aug 25, 2011 | Bose & Wave& Music System
How can i bypass the stock amp in a 2000 pontiac grand prix with the bose speaker system in it with out taking the bose speaker's out?
you can't. the bose system is just that, a system. you need all the pieces for it to work. the head unit doesn't have any power and you need the amp to drive the speakers. also, bose is a proprietary system. only bose parts will work for it. so you can't buy any amp off the shelf and swap it out. if the amp is bad you need to buy a replacement bose amp or replace everything with a new head unit and speakers.
Apr 12, 2011 | Car Audio & Video
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
Bose SoundLink Air digital music system with Apple AirPlay Logo
42 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
