I have 8 year magnovox 42' it would turn off by it self now it will not turn on need some help please
  • 1,915 Answers
At eight years old, likley the power supply is failing. You can try unplugging for a1/2 hour and then plugging it back in to see if you get any power lights or hear any noise. If it makes noise for a second and then cuts out, it is very possible that the power supply has some bad capacitors on it. Depending on your level of technical ability you can either find another power supply or change the capacitors. If you look at the power supply, any capacitor that is bulging on top is bad. Really bad ones will look like they are leaking with a residue on top.
Posted on Dec 06, 2014
I have a 42 inch Dynex tv have had it for about 2 years now its starting to just cut off by its self. HELP!!
Try changing the input device to something you are sure works. Look for any loose contacts in RC jacks/sockets/Cable. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Blinking red light, i tried to turn on 50" magnovox all i get is blinking red light generally when i turn on a green light comes on then tv c omes on short time later model # is 50MF231D/37
You have problems with your power up circuits. It is more than likely a fuse blown in some part of the TV that is keeping it from coming on. Also almost everything from a Computer to a $10.00 Calculator starts up by running a self diagnostics test on it's circuitry and if it detects any problems it will shut down or will go into a standby mode. Your TV has detected a problem some where in the circuitry and went into 'safe' or 'standby mode'. As I said in the beginning it could be a fuse, then again it could be about anything. I'm saying fuse because the heating and cooling of the element in the fuse often leads to metal fatigue and causes them to open up. Check the back and see if it has a 'user friendly' fuse panel and go from there. Look for a 30 amp blade fuse [it will be green] and see if its blown. I think that model has a history of blowing that particular fuse. If not, and you are not experienced in TV Repair don't attempt to take the back off and fix it your self, because there's places in there that will fix you good. You will need to take to a reputable TV Repair shop. I hope it's the fuse and that this helped! dhgill1949
Sep 04, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips Magnavox 42 inch plasma white strobe-like blinking
magnovox 42 inch pasma shows tv guide but does not show pciture.
Sep 23, 2009 | Televison & Video
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
Need tv codes for magnovox misplaced code book
Hey there juice0619
MAGNAVOX ..... 002 009 109 118 209 309 402 408
502 508 510 807 914 917
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | One For All URC-3021 Remote Control
Need code numbers
Go to web site. it has download for codes
Sep 03, 2008 | Toshiba 42H81 42" Rear Projection...
Magnovox TV
On many of these (I am not familiar with this exact one) you push the volume up and down buttons on the set (not the remote) at the same time and hold them for a second or two. Try this. Philips has a customer help line that can help you as well, but expect a long wait and much irritation.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
