Question about GE Microwave Ovens
How can I remove the front door of GE microwave oven, model zmc1095sf?
Not much, except examining the oven in detail. I thought if I could remove 4 screws on the bottom of the door, then I should be able to remove the rest. Unfortunately, the space between the bottom of the door and the oven frame is only about half an inch so that there was no way I could remove the screws.
  • 1,921 Answers
I was told those machines are not made for us to repair. All that stuff is throw away models.
Posted on Jan 13, 2015
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Posted on Dec 05, 2006
SOURCE: How to remove the outter door frame on the GE Microwave
I think some of my cleaning solution seeped down in the front door of my microwave and now it has this oranged burned spot in places. It looks like the door is dirty but the residue is actually in between the glass of the door. Any suggestions for what to do? Should I try to take off the door and clean it or buy another door for it?
Thanks! Amanda in Alabama
Posted on Mar 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Posted on May 12, 2009
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Crack in GE jvm1631wb004 Door
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
For most models, you can order just the part that's damaged.
Jun 07, 2009 | GE JVM1631 Microwave Oven
GE microwave Model JVM1540
If you mean the control panel, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you mean the door, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 16, 2009 | GE JVM1540DM Microwave Oven
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Parts for Model JVM230WLC
Are you looking to upgrade it cosmetically or does it have a problem?
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To replace the outer door panel, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove for disassembly.
Jan 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to install charcoal filter in ge microwave md# jvm1870 sk04
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can order new filters by entering your full model number here.
Sep 19, 2008 | Microwave Ovens
Door hard to open on GE Advantium
That's odd.
I think you're just going to have to examine it while opening and closing the door.
That can help. Good luck.
Aug 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | GE JVM1440 Microwave Oven
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Nov 30, 2007 | GE JE2160 Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
