Question about Frigidaire Refrigerators
No light in refrgator after new board installed
Installed new board an no lights in refrigator
  • Frigidaire Master
  • 10,291 Answers
Is the bulb known to be good? Is the door switch working? These need to be checked too.
Posted on Dec 06, 2014
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
The refrigerator temp lights are flashing on and off and its making a clicking noise..ge profile refrig with freezer on bottom. I unplugged for 5 minutes and replugged with no help
your main-board/motherboard is bad,a telltale sign is,if just recently had light bulbs burn out in the refrige compartment and now they strobe dimly and the digital temp readout is also out and you sometimes hear relays clicking back there, the board took a voltage surge and ruined the circuit trace,replacement is simple,unplug 3 harnesses and snap in new board and plug in new board and youre good to go
Feb 22, 2010 | Refrigerators
Light in refrig not working & blue indicator lights out also. Pulled switch & lights still out if I jump the leads. Is there a reset botton.
your motherboard in the lower rear area of the unit is bad,if you have recently replaced burned out lights in the refrige when these lights burn out it causes a surge on this control board and burns the circuit trace,hint:if you hear a rapid clicking noise in this area of the motherboard its a relay trying to latch,a bad board wont let it latch and the lights will dimly flash in the refrige compartment and the digital read-out may be out too
Jan 24, 2010 | Whirlpool GS6SHEXNL Side by Side...
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool custom series frig & the bulb has gone out. After switching it with 2 new bulbs with no results, I wonder if there is an electrical problem? Additionally, what appears to me to be...
Yes KariAnn,
I have replaced 3 of these this week already, its the control box,lower left corner inside white plastic box, when light bulbs blow out it surges& the control board is ruined, its quite common, replace it with a new board no need to replace the cover or box with a new one, go to appliance parts pros or call 1-877-477-7278, the cost will be about $85.00 with shipping included, UNPLUG REFRIGE FIRST, and remove control board(2screws) on back of refrige, take off plastic cover and unplug 3 wire harnesses and install new board put cover back on and its good to go......if you have any other questions I'm at dmftrucker@yahoo or 24/7 Appliance Service (608)214-5632....Regards Daniel
Oct 08, 2009 | Whirlpool Refrigerators
The two lights are on refrigerator donot work
id be curious as to if there is a control board locatd on the sidewall next to the compressor, behind the refrig. usually encased in awhite housine mounted directly to the cabinet, ifso I'd open that boxup andlook for a burn mark, that s the culprit for no interior lights in refrig
Mar 12, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Refrig light out, but lightbulb is new
you dont know how many calls i ran about light buls not turning on and when i get there is loose try giving and extra turn to tighten remove and re install tigh if is not commimnog it might the light switch or loose connection inside.
Oct 31, 2008 | Whirlpool 21.6 cu. ft. Top Freezer...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
