Question about Spektrum Dx6i Computer Radio
How do I adjust dual aileron servos
I have the aileron servos connected to my recvr. And selected dual aileron screen. But it does,nt indicate exactly how to program the travel of each one Please help. Thanks. Jim
    Problem Solver:
  • 5 Answers
If your talking about 2 servos per aileron (4 total) I think you'll have to use 2 "y" connecters and sync the mechanically. I don't think it has provisions for 4 aileron servos. For 2 you adjust them in sub trim.
Posted on Dec 06, 2014
Transmission park &reverse not shifting into gear only gets drive need a why need solkution ?
run fault codes and check for a TCM problem or servo/ solenoid s for the gear selections.
Apr 25, 2014 | Ford E-150 Cars & Trucks
No reverse after i park my 1962 ford automatic
Fluid level and a dirty filter are the first things to check, then a band adjustment is next on the list. as the pan needs to come off to change the filter adjst the bands at the same time. the tea levels in the bottom of the oil pan will tell you in there are more serious issues inside.
Terry
Nov 25, 2012 | Cars & Trucks
2004 Toyota 4Runner Dual Control Heat cold Passenger side
The fuse your looking for is under the hood in front of the driver
Oct 12, 2012 | 2004 Toyota 4Runner
What are the ailerons parts of the airplane?
Ailerons tilt the wings of the planes by pushing down the air. Ailerons on both sides work in opposite directions. As one aileron moves up, the other aileron moves down. This helps the airplane to turn during flight.
Aug 29, 2012 | Champion Sport & Outdoor - Others
When are the spoilers parts used in airplanes?
Spoilers are used during landing in order to increase the drag of the wing and decrease the amount of lift. They have two functions during flight: make the airplane descend or slow the airplane down before landing. Also, during landing, the spoilers are used in order to keep the plane on the ground and improve the efficiency of the brakes.
Recvr produces no sound from speakers,is there a factory reset sequence i can do to get rid of all settings i have made?
Maybe there's a simpler fix. Examine every indicator on the front and understand what they mean.
Un-select anything to do with Tape or Muting. Disconnect the headphones. Properly select the input. DE-select EXT IN.
The manual is free after registering at http://audio.manualsonline.com
search for Denon AVR-689
Feb 13, 2011 | Denon AVR-689 Receiver
The dishnetwork. Sighn just dances around the screen I push select and nothing happens
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
Nov 16, 2009 | DISH Network IR Remote Control
How to connect my compaq v2148ap laptop to tv using svideo??plss help fast....i dnt have the vga wire i have the 7 pin wire!!
Do not use a cheap cable !
Use a good quality cable
You also need to tell your computer that it has another display available to it
to do this RIGHT click on a blank area of your desktop then select properties.
Now click settings If you can see TWO screens with the number 1 and 2 on you are already part way there
Now click Advanced.
If you see a tab that is for your graphics card select it
From here you should be able to tell your laptop to use multiple displays
You should select Clone (if you have dual-view available then select that)
You may have to lower the screen resolution at first and maybe even adjust the two displays individually
If there is an option for "detect my tv" that would also be a good starting point.
It does vary from card to card and even computer to computer for the exact steps.
With any luck you should now have two displays and it would be just a matter of making minor alterations to make the two displays suit your taste.
Be aware however that not all computers with Svideo may work with a regular tv. This process works best with flat screen lcd and plasma tvs
Aug 22, 2009 | Compaq 389897-001 - HP/ Presario V2000...
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
Spektrum Dx6i Computer Radio Logo
98 people viewed this question
Top Spektrum Toys Experts
ray gallant
Are you a Spektrum Toy Expert? Answer questions, earn points and help others
