Question about Home Security
How do I get the safe door open when the battery power is weak? My Futura safe is old---more than 20 years. It has the electronic keypad and runs on "c" batteries I believe. I punch the code in but th
Nothing beyond punching in the 6 numeral code repeatedly. The beeps get weaker and weaker. Should I contact a locksmith in my area to break the safe open? Of corse, I realize this will ruin the safe.
  • 188 Answers
SOURCE: I punch in code safe will not open
Go to sentrysafe.com for support.
Posted on Aug 08, 2009
  • 3197 Answers
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
Posted on May 29, 2010
  • 132 Answers
SOURCE: I changed the battery in my winchester digital
was there not a key also? if not then remove the new and start over, if it still wont open refer to your paperwork that came with the unit there is always a number to call for questions.
Posted on Oct 16, 2010
alpug
  • 1961 Answers
SOURCE: Have had a CSW 3813
Sounds like you need a new battery replacement.
To replace the battery pack, unscrew the screw below the electronic lock case, turn the lock case to the right then remove it.
You can have the online manual from the link below, just make sure you have installed the adobe acrobat reader on your computer to view this file cause its pdf format.
http://www.sentrysafe.com/pdfs/OwnersManuals/503662.pdf
Additional info can be found from this electronic safe sentry manual
http://www.sentrysafe.com/pdfs/OwnersManuals/505748.pdf
If the problem leads to acquiring the right combination for your safe.... call the attention of Sentry Safe Shop
You must call (800) 828-1438 for combination retrievals.
or send a notarized letter stating you are the owner of the safe, personal information, model and serial number of your safe and must indicate the method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
Posted on Apr 06, 2011
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
My lagard lock safe won't open-no battery.
If internal battery is depleted and will not allow lock to open, hold a new9-volt alkaline battery on the contact points (large battery terminal to
large keypad contact, small to small) located on the front of the keypad.
Maintain contact, enter and valid code and turn keypad to open lock.
Lock contains a non-volatile
memory, even with batteries removed the lock will retain
all programming.
NOTE: You must maintain battery contact at all times throughout the
entire procedure.
Mar 15, 2014 | Safe International Digital Electronic Safe...
I forgot my password to my youniverse electronic vault, how do I open it
That is a picture of the Youniverse Electronic Lock N Safe.
Power up the safe (3 x AA battery);
Remove the batteries, then press any key on the keypad;
Replace the batteries & the safe makes a creaking sound;
Factory default open code of 0000 has now been set;
Enter 0000 on the keypad then turn knob counter-clockwise & pull door open.
Jan 05, 2014 | Summit Appliances Division Youniverse...
Change code on Futura wall safe
Refer this problem to Futura
May 24, 2013 | Locks & Locksmithing
I came home last night and when i enetered in the code to the door, a green light came on in the back of the unit, a noise alarmed and the door did not open. Does that mean that the battery needs to be...
I just had this problem with a model 909. The batteries might be too weak to move the bolt. See if it will move with the door open. Unfortunately, if it's more than a year old, it's out of warranty and no parts are available to repair the electronics. I replaced mine with a different brand, which doesn't drive the bolt, it simply enables the bolt to be moved by hand.
Aug 10, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
My wireless remote keypad stopped working. I changed the battery and it worked to get the garage door down but not up. The key pad is about 7 years old.
It sounds like your keypad is going bad and has a weak signal. It can operate the opener with the door open but with the door between it and the receiver it can't.
May 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jun 07, 2009 | Sentry Fireproof Safe
Electronic digital safe richmond
after six years of good service the batters ran out when we were not at home sadly after all this time I cant find the security key to open my safe the number of it is ho 155 how can I get a new key
Apr 07, 2009 | Safe International Digital Electronic Safe...
Batteries weak
Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Feb 08, 2009 | Safe International Digital Electronic Safe...
Home Security Logo
57 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
