Question about Vehicle Parts & Accessories
Pinto/ mustang II rack and pinion install on a toyota camry
Has anyone tried to install a pinto/ mustang II rack and pinion, like the ones from jegs, on a 1994 Toyota camry le sedan with the 2.2 4cyl engine and automatic transaxle?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
I believe that the rack for Mustang 2/pinto, are mounted in front of the axle center. When the design of the original for your car is behind. Knuckles will need to be switched from side to side and input shaft will need to be extended and a few u-joints installed. Would be more practical and safer to get an original /oem/re manufactured unit.
Posted on Dec 06, 2014
What is the torque spec for a 1978 Ford pinto differential pinion nut?
170 ft.lbs is the minimum; be aware that this differential uses a crush sleeve to set the backlash and the pinion torque is what crushes the crush sleeve. If you don't set the backlash correctly you can grind up your differential gears.
8 Inch Ford Rear End Torque Specifications eHow
Feb 02, 2015 | Ford Cars & Trucks
Manual rack and pinion
Talk to a steering specialst shop about how to remove the valve assembly from the powered system to allow the rack to move manually. failing that stick with toyota products and go back a few years before power steering was the norn.
Dec 04, 2014 | Cars & Trucks
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
1991 toyota camry stiff steering no leaks, safe to drive?
No, it is not unfortunately. This may be an indication of impending total failure, and you can't really handle the car well in traffic.
If the reservoir fluid level is OK, then the next thing to check is that the drive belt is tight enough to drive the steering pump.
If that appears OK then either you have a fault inside the pump or steering rack valve, or there is something binding in the steering knuckle ball joints, and that will need a specialist.
May 12, 2012 | 1991 Toyota Camry
My toyota camry steering went very stiff
Unless the rack and pinion gears are slipping (jumping a cog), then try putting oil on the universal joint in the steering column just above the rack & pinion. Two mechanics wanted to change the rack & pinion for $900 or the "Yoke" (whatever that is) but a generous squirt of oil on the U jont fixed the problem for my 2002 Camry!
Aug 11, 2011 | Toyota Camry Cars & Trucks
Have a kit car with a ford 2.0 ltr pinto sohc,rev counter wiring
Most rev counters of this type wire the positive wire to the contact points on the distributer and the black (negative) to ground.
Apr 16, 2010 | 1978 Ford Granada
My 2005 aveo horn does not work I replaced the fuse and still not working
see if the horn will sound as you turn the steering wheel hard in both directions. a lot of time there are this connecting rings in the steering whell that make connection with the horn operation. these rings get worn just by driving even when you haven't used the horn. I hope this is not the cause because it can be costly. many times the fix is to replace the wheel. I had a toyota once and also the ole' pinto that had thses symptoms. both cars had the same cause. the toyota had to have another steering wheel. I can't remember what I did with the pinto. ( I do remember a funny story with the pinto, I lived in an apartment complex and one night at about 2a.m. the horn started blowing, I waited for a while then got mad at who ever is keeping me up I stormed outside and behold it was my ford pinto. I think I remember destroying the center of the wheel to get the horn to stop.)))) hope this helps.
Jun 11, 2009 | 2005 Chevrolet Aveo
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
