Question about Bladez Exercise & Fitness
I am in need on a power cord for the bladez 9.9t treadmill and bladez no longer carries them. Can someone direct me to where I can find one.
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
We need a ceramic fuse for the control board for a Bladez BF 6525 treadmill. We do not know the amps and have been unable to find one that does not blow when we start the motor
If you have the old fuse you could take it to an electronics store in you area and see if they could help you identify it. You could try a place like radio shack but they are not much help with components. Also if you have the old fuse, look for numbers on it a try typing them into google.
Feb 17, 2013 | Bladez 6530 HRP Folding Treadmill
Bladez prisma treadmill error e1 replaced lower control board and speed sensor
I will answer my own problem here, maybe it will help someone else. After BH North America customer service told me I needed a new lower control board and I had to spend $100+, it wasn't the board. Then they said it was the speed sensor, they sent that out for free, that wasn't it. Now, they would not respond to me. So, we went off the troubleshooting guide saying it was a connection problem between the upper and lower board. My husband opened up the "leg" of the treadmill and checked the connections (cutting the tie cords that hold the wires tightly in place, maybe too tightly and that's what caused them to come unplugged) and now the belt runs! So, BH got another 100 dollars of my money, on top of the original $800 and solved nothing and then ignored my emails. Horrible customer service and when this one finally bites the dust, I will never purchase a machine from them again. P.S. This treadmill is only approx. 2 yrs old.
Feb 12, 2013 | Bladez Fitness Prisma Supra Folding...
No power to console on bremshey scout treadmill
Replace 12a 250v ceramic slow blow fuse 5 X 20 mm on power board.
Jan 10, 2013 | Bladez Exercise & Fitness
F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Dec 31, 2012 | Bladez Exercise & Fitness
I have an everlast folding treadmill and the machine starts fine but then it speeds up and and stops and the display say E1. I tried adjusting the belt but to no avail. Please help. Thank you.
if your everlast speeds up all of a sudden it is your speed controller and this is useally caused by you not lubricating under the walking belt, a dry belt will cause friction which causes the motor to labor harder and then over time your motor will over heat and cause speed problems,
or buy pluging your power cord directly into your out let the surges with cause your controlle board to fail over time u must plug the power cord into a 15amp surge protector with min 500 jouls and 1 plug at all times,
you should always have a anti static mat under the whole treadmill if your treadmill is on carpet static can de magnatize your motor, and static will be pulled into the treadmill
so when u step on your treadmill u become charged with static so every time you touch your computer console you are causing little charges to your console which over time cause the computer to male fuction,
also watch out for useing cheap exstention cords they will cause major damage to your treadmills electronics and motor they can not carry the proper voltage from the outlet into your treadmill so this will daMAGE YOUR TREADMILL ALWAYS USE A HEAVEY OUT DOOR THICK EXSTENTION CORD make sure it is 15 amps and a heavy gage and no longer the 10-15ft
the longer the exstention cord the more power you loose
Tim Ramsay
Lubeatread Inc
lubeatread@sympatico.ca
16 feb 2011
this goes with all treadmills
Jan 27, 2011 | Sport & Outdoor - Others
Elevation is elevating in the wrong direction
Unless this unit was physically re-engineered,either the rear end incline on some models or from the front depending on the mechanism look closely when you fold it up chances are you will be able see that mechanism thru the bottom cover slot made bigger for the rear wheels to move.
Apr 09, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Exercise & Fitness Logo
61 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
