Question about Singer 2273 Mechanical Sewing Machine
Singer 2277 buttonhole makwer makes half way then doesn't sew other side, or doesn't go past first step I've followed instructions step by step about 2 dozen times. I got 5 good buttonholes out of about 3 dozen. what's wrong
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
Make sure your buttonhole lever is all the way down (I think it probably is, if you it will sew some of the buttonhole), and also sure that your bobbin winder is not partially engaged. In other words, make sure it's all the way to the left.
Posted on Dec 20, 2014
SOURCE: singer 7436 buttonhole problem
I have found that the problem lies with the button hole pull down. Either it is too far down, or too far up. The problem that I have with it now is that it will never sew the button holes consistantly. I will set it where the button hole needs to be, and it will then proceed to place it where it wants to. Any help on this problem?
Posted on Apr 20, 2008
keemo68
  • 1263 Answers
SOURCE: Singer 7462 buttonholer
generally most sewing problems are due to sticking parts because of non usage as =you have stated or because the tension has been not set right. what I suggest is that you take the time to do some cleaning of the machine like what bis pointed out in your manual use a light weight mineral oil to wipe the moving parts with, but not too much. also adjust the tension of the foot so there is pressure on the material as to move it while sewing. after all the cleaning and adjusting rethread the bobbin and make sure it is seated properly also rethread the need and make sure the thread moves freely from the spool. this should do the trick. please rate this
Posted on Sep 29, 2008
SOURCE: buttonholer on Singer 2639 sewing straight ahead
Also make sure that you pulled the buttonholer lever down and pushed it back (it's on the left side of the presser foot) ... the machine won't make the forward and backward motions to form the buttonhole without it.
Posted on Aug 06, 2009
  • 139 Answers
SOURCE: SINGER 7422 28 STITCH 2 BUTTONHOLE INSTRUCTION MANUAL
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
  • 139 Answers
SOURCE: I have a Singer 2662 sewing machine. The
This website should help: http://www.singerco.com/resources/buttonhole.html
Posted on Apr 16, 2010
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
How do I fix a onestep buttonhole that is sewing only on one side?
I am giving a link for the basics of a one step button hole. Next time include the machine make and model for addtional help.
One Step Buttonholing
Mar 01, 2015 | Singer Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
When I press the button to make a buttonhole and step on the power, all I get is a beep. How do I make a buttonhole in that one easy step?!
Is there a little arm you need to pull down behind the presser foot? And a buttonhole foot that needs to go onto the machine?
Do you have a manual for it to check out the buttonhole procedure? try this link
http://www.singerco.com/resources/buttonhole.html for some instructions and images but always good to have the machines manual if you can get one.
Many of the machines with the one step buttonhole function have a white plastic slide type foot and the buttonhole lever that you pull down. You put a button into a clip at the back of the foot to "measure" the buttonhole length. Then start sewing, the machine will do a bartack, then start backwards, the pulldown lever will then connect with the foot when it gets to the right length, start the end bartack, then reverse back up the other side of the buttonhole and finish off when it comes back to the start of the foot.
The Singer will probably be some variation of this system, hope this helps.
Mar 09, 2011 | Singer 7422
HOW TO USE BUTTONHOLE FOOT AND WHAT SETTINGS ON MACHINE
From what I could find, this machine has a one-step buttonhole feature.
I found these instructions for a Singer one-step that may be of help - http://www.singerco.com/resources/buttonhole.html
May 08, 2010 | White Sewing 955 Mechanical Sewing Machine
Singer 2273 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
