Question about Optics
Any information on WM24 Type Scotopic night vision
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Jan 04, 2017 | Aircrafts
Where can i find a BAIGISH Sakura 10-70X50mm Night Vision Binoculars Scope user guide/manual online?
Dino Direct carries them and has a pretty good description for them but is not complete. If they opearte in the manner I think they do, hold down on the lever to power them- do not pump, just press and hold. Since there is no mention of a battery or cell, this is the usual alternate method to power them.
Otherwise the online information that is most complete is http://www.dinodirect.com/sakura-scope-10-70x50mm-binoculars-night-vision.html
Jan 12, 2012 | Optics
Repair: Night Owl Lightweight Night Vision Monocular?
First, what are the problems with your Night Owl monocular? I can't help you. You'll need to give more information on what is wrong with the Night Owl monocular. stewbison
Aug 16, 2011 | Night Owl Optics Optics
I search for my Baigish 12 USSR made an new akku
What type of trouble you have with your Red Star NV devise? If you are trying to search for the Russian manufacture. Then use this as you search "Manufacture image intensifier tubes" and "Manufacture of night vision scopes, monoculars and binoculars" The search engine will list the manufactures of these devises through out the world. stewbison
Jul 28, 2011 | Kalinka Baigish 12 Russian Night Vision...
I've got NOCX3M Night Vision, It has developed a
Jinko! Now is this NV monocular yellow in color? What type of chemical did you clean with? Any thing that petroleum in it, or corrsive chemical will desolve the PVC plastic cover. Probably what happen there was harah chemical used to clean the monocular, it weaken the top cover of the PVC frame and made it a gooy surfaces. The material in the frame is not water soluable. Try to dry it out, then scrap it off then sand it to a smooth surface. stewbison
May 06, 2011 | Odyssey Night Owl Optics - Explorer Marine...
Have a camo binoc that only markings are CHINA and NIGHT VISION...but cant find battery placement....might not truely be night vison?
Hello, Kalinka Baigish is Russian and they do make NV devises but China? Now, the Chinese do manufacture NV Image Intensfier tubes to Generation 2 but manufacture the hole night vision devise is new to me. Of course, about 1/3 of the world countries manufacture some sort of night vision devises or there parts.
Contact Night Vision Optics they sell these Russian night vision devise under the brand name: Night Vision Optic and they have a logo. There are only companies in the US that manufacture night vision stuff. Also, some of the US companies do use US image tubes and other electronic components, and maybe US optics are used. GB...stewbison
Jan 09, 2011 | Kalinka Baigish 12 Russian Night Vision...
What kind of batteries do i use and where do the batteries go?
Hello David. David you night vision doesn't use any batteries that one installs. You have Kalinka Zenit NV monocular that is Russian manufactured but is sold by Night Vision Optics. Your night vision uses a piezo electric ignitor to charges the batteries and charge a couple capacitors.
The lever on top to the Zenit monocular is activated by squeezing the handle that is covered in a rubber type material. Just keep squeezing on the lever and in while things will start working. Best of Luck David. GB...stewbison
Nov 11, 2010 | Kalinka Zenit NV Piezo Russian Night...
I DON NOT HAVE A MANUAL OF night vision atn 330 warrrior , I NEED BEACAUSE I LOST...
What is the serial number of your 330 warrior, so i can give u the manual in pdf format, or simply provide the information to
info@atncorp.com
ATN corp
1341 San Mateo Ave., S. San Francisco, CA 94080
800-910-2862
Dec 17, 2009 | ATN Night Vision Rifle Scope; Aries 330...
Does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Mar 13, 2009 | ITT Night Quest 220
Fujino Stabiscope S1240d/N
I don't know about the night vision bits but if it is the same as S-1240 then the 3-pin plug is a power input.
Regards,
Tony
Feb 01, 2008 | Fujinon Stabiscope S-1240 Binocular
Optics Logo
46 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
