Question about Dryers
My frigidaire dryer will not come on. It is plugged in. What could be the problem?
  • Dryers Master
  • 744 Answers
Hello Valinda;
My name is Peter. I am a retired field service appliance technician.
There are several low cost components that are preventing your dryer from starting.
It could be a bad door switch, bad thermal fuse, bad thermostat or a bad motor pulley starter switch.
I will help you, but I need your model number so I can see exactly what you have.
Posted on Dec 06, 2014
I have a frigidaire affinity dryer and when I try to plug it in it trips breaker immediately
Hey Robert, thank you for your post!
I understand that your Frigidaire dryer is tripping your circuit once it has been plugged in. This could be a possible issue with your power or the in home circuit. You may need to have an electrician out to review your in home circuit to assure that everything is operating properly. Hopefully this will help correct your problem. -Matt
Jan 05, 2016 | Frigidaire Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
How to change a 3 prong plug to a 4 prong plug on a frigidaire gallery electric dryer
where the green ground was attached to the body it will now be attached to the middle prong? u can use youtube to see how to go from 3 prong to 4 prong if this is confusing
Jun 10, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire gas dryer will not heat
Good Morning Margie,
I see that you are having trouble with your Frigidaire gas dryer heating. I also see that the vent is plugged. You definitely do not want that vent plugged. Your dryer needs proper ventilation in order for it to work correctly. The reason it might not be heating is due to the fact that that vent is plugged and is not getting enough ventilation. Unplug that vent, make sure that there is gas going to the appliance, and that the gas supply valve is open.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire AGQ6000ES Gas Dryer
Just rebuilt my Frigidaire dryer, new heat coil, temp sensor, and bearing kit, pluged in worked good, opened door and sparked, found i didn't plug in light wire touched, now it won't go, did I blow out the...
Good Afternoon James,
I understand that you rebuilt your Frigidaire dryer, found that you didn't plug in the light wire and it sparked. Now the dryer won't go. From this point, I would suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and see what is causing your appliance to not go. Hope this is helpful.
-Best Regards-
WP
Mar 10, 2014 | Frigidaire Dryers
My 2009 Frigidaire dryer door won't open
un plug the dryer for two minutes let it reset , then plug it back up. see if this helps you.
Feb 11, 2013 | Frigidaire Dryers
Four wires fell off my frigidaire dryer and I can't read the diagram to put them back on
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 14, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
