Question about Uniden Cordless Phone
My phone only gives my a busy signal and won't receive or send calls. What should I do?
Resetting the phone and checking with the service provider. Nothing seems to help.
    Master:
  • 966 Answers
Gene, first make sure each of the units is properly docked and off. Check the telephone connection from the wall to the main base unit. Busy signal tells you a unit is busy - not turned off and not in the dock. GL
Posted on Dec 06, 2014
GE phone model 29581 does not seem to have instructions for resetting voice mail ...my phone just keeps ringing and won't go into voice mail
Voice Mail is not a function or feature of any telephone set,
nor does the GE 29581 phone have an Answering Machine
System that might be confused with Voice Mail.
VoiceMail is an option offered by some (not all) Telephone
Service Providers. Check with your Telephone Service
Provider to learn how to go about using theirs if it's available.
The original GE 29581 phone User's Manual is available at: http://www.manualslib.com/download/59417/Ge-29581.html
Mar 18, 2016 | GE Lands Phones
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Can't send or receive multi media text and picture text won't download when i get them
Contact your service provider and ask them to send settings to your phone. Its quick and free.
Jan 21, 2013 | Cell Phones
What did the upgrade do to the zte warp so it no longer gets service?
ZTE Software Update has nothing to do with the Service of your device. You could try resetting the device from the Factory Defaults option and check if would work. IF the issue still persists, then you could contact your service provider for further assistance.
Jan 09, 2013 | ZTE Warp
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
My lg c555 won't send text messages
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 12, 2012 | LG Cell Phones
I need to delete all these 163 messages in my outbox im not able to unlock or delete them i need help i even tried resetting the phone it doesnt help...
Please provide full details about problem and component, it help us to understand the problem.
could you please tell me the phone brand and model? and can you delete the messages from the Inbox? and check that you have the message in your phone memory not in SIM. if nothing help then you have to reinstall a latest firmware of your phone as your phone's software may got corrupted.
vote me if found helpful.
Aug 05, 2011 | Cell Phones
Won't send or receive phone calls.....I live in Australia...
hee is some guide :
* try to replace another sim and check if can receive or send calls
* also try the current sim into the other mobile if its working or not...
conclude weather the mobile or the sim had a problem
* also check the signal stability if its ok... might get some network failure if its dropping or
the mobile itself has the problem...
* lastly,try to reset the phone so all settings is refresh,but before doing reset,make sure you back up all important data of yours before proceeding..
hope it helps...please rate me...thanks...
Jun 04, 2011 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My blackberry won't send or receive either texts or calls. But I can still do everything else like browse the web or send bbms..
This problem could be due to the lack of GPRS service. GPRS stands for General Packet Radio Service, and it's what allows your device to access data. The first thing you should do is perform a soft reset. If that doesn't work, perform a hard reset. After both resets, check your wireless antenna signal strength. The antenna should show GPRS. If you can still make phone calls and access the Web, then your GSM service is still available. Try sending yourself an email . Does it work? If it doesn't, call your BlackBerry provider. Sometimes, your service could be delayed due to a billing problem or to downtime on the network.
May 17, 2011 | RIM BlackBerry Pearl 8100
I have a nokia 5230 and my outgoing calls are deactivated and i need a barring password
Please check this up with your service provider to confirm that the fault is with the phone as the barring can be also activated by the provider. So please check this out and confirm. If not the phone needs a resetting or a software re-installation.
Mar 24, 2011 | Nokia 5230 Cell Phone
Uniden Cordless Phone Logo
144 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
