Question about Whirlpool Home
I have a swirlbath whirlpool tub and the air hose fell off the push button switch on the side of the tub. The tub is 19 years old and the switch is against the wall side of the tub. How do I hook it u
Nothing. I don't know how to get the switch out so I can hook up the hose.
    Scholar:
  • 80 Answers
Yo Dennis,
When I had to replace a switch on my unit I had the same problem. Jacuzzi uses double sided tape to hold the switches in place and they are a bear to get off. Try some dental floss or fishing line under the switch body to "saw" through the tape and lift the switch out. Maybe use a hair dryer first to try to soften the adhesive, but at 19 years it may be rock ??.
You may have to pry the switch out (!!) with a screwdriver (rag underneath) and the old plastic may grenade. A new one may be needed.
Be prepared for very little slack in the air line. I had a hard time reconnecting mine and ended up having to add a couple inches of tubing with adapters. No fun. The switches are mounted from below at the factory, so slack is not an issue.
All the best.
Posted on Dec 11, 2014
We turned on our soaker tub, ran it for a bit, then it wouldn't turn off. I then flipped the circuit breaker off and now the tub will not start when you push the start button. Model B950.
If the switch is an air type switch check the tubing connected from the switch the control for kinks or pinched spots. This could be the cause of the problem. Hope this helps.
Bob
Jul 04, 2014 | Jacuzzi Tara, Whirlpool Bath -...
Find air switch for aker swirlbath
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. You need part # TBS-310
US Parts Center
Feb 14, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
Mirolin jaccuzzi tubs
Air Switch Repair
US Parts Center
Jan 28, 2014 | Home
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
US Parts Center
Jan 11, 2014 | Home
Jacuzzi majic touch won't turn on
Air Switch Repair
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a American Standard Corner Whirlpool Year 10-10-03 Model 752857-300 When I push down The air switch button down The whirlpool come on But when Push again it will not cut off I check hose going to...
US Parts Center
Sep 27, 2013 | American Standard Home
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
I have a whirlpool bath in my master bath in my mobile home, years ago my grandson pushed the button to activate the jets without water in the tub, it hasn't worked since, yesterday I had a friend who is...
the air switch should be connected to a switch by the motor the air switch is ur on off and should run from the button to another switch by motor the air switches were put in so there was not live wiring by the tub surface ,the the tub button/switch is like a bellows and pushes air into tube to turn switch on/off
Mar 04, 2010 | Kohler Home
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
138 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
