Question about Pioneer Televison & Video
Can you replace the SD-M1712B DVD Player in a Bose AV28 with a BluRay player?
Trying to install a Pioneer BDC-207DBK BluRay player
SOURCE: DVD Player not working
I have the same problem this is the 2nd one i have bought and this is the only one i have gotten a problems with when ever i find something i'll let you know
Posted on Apr 22, 2007
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SOURCE: Remote control code for Sony BDP S350 Bluray player.
Try code 32907
Posted on Feb 22, 2009
SOURCE: I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
Posted on Mar 09, 2009
SOURCE: How can I unlock my LG BD560 bluray dvd player so
http://www.videohelp.com/dvdhacks/lg-bd560/10815
Posted on Sep 17, 2010
Just got a rather nice PIONEER BluRay player and streamer - model number is : Pioneer BDP 160K BluRay multiregional , no problems, but it will not cooperate DVD-wise with a multiregional player, having a...
Takes a firmware flash to change region codes. This is not possible most of the time because the companies dont share that on the web. Good luck
Jun 13, 2014 | Televison & Video
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
I am looking for multi zone crack for Pioneer BDC-TD04 (Sony Vaio laptop) Blu Ray drive, suggestions?
DVD REGION FREE & BLUE-RAY REGION FREE
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Apr 09, 2012 | Sony VAIO C Series Notebook VPCCB17FXW
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Universal remote code for samsung bluray dvd player
I have a Samsung blu-ray dvd player,non of the codes seem to work with my universal remote.
Help.
Dec 06, 2008 | Bose Cinemate Digital Home Theater System...
Lost directions on how to hook up my Bose model AV28 media center
Go to Bose' website and click on "support". See if that helps out...accordianman
Feb 26, 2008 | Bose (321GS) System
Televison & Video Logo
44 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
