Question about Hamilton Beach 35030 Deep Fryer
Wire diagram to make sure three wires are connected correctly to the lighted rocker switch
  • 24 Answers
Normally the neutral lead of the lamp is a different color. If you have a ohm meter you can use it to look for a short between two terminals, this is the switch. The lamp is likely a neon lamp that you can not read with a meter, neon must have over 60V to light.
Posted on Dec 24, 2014
I am hooking up a leviton 1755 3 rocker switch that controls a light, fan, heater all in one ceiling unit. The old switch had the white wire in the top switch, one black in the middle and the other black...
1) Look at screw color.
New device has brass screws on one side, and 1 silver screw for each switch located on other side of device.
Hot wire goes to brass screw.
Wire to fan goes to one silver screw
Wire to light goes to another silver screw.
Wire to heater goes to another silver screw.
If you do not have a wire for each individual Load, then you will have to add wiring.
2) Electricians don't guess, they test.
Separate wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
Hot wire connects to brass-colored screw.
If any wires on old switch was connected to same Hot wire, then also connect that wire to brass-colored screws.
Hot wire is identified.
Test Hot wire to each other wire in box, except bare ground.
Tester lights up on Neutral wire. Neutral wire will NOT connect to this switching device.
Next, connect one of the remaining wires to a silver screw.
Turn power ON.
Flip switch to see what Load that wire controls.
By process of elimination, add wires to each silver screw and test each by flipping switch.
Breaker will trip if you connect Neutral to silver screw.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 10, 2011 | Leviton 003-1755-W Three Rocker Switches
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
3 way switch diagrams
Three way switch diagram: Three-way switch has 3 screws
Before replacing old 3-way switch, mark the wire connected to dark-colored screw
Connect that wire to dark-colored screw on new switch.
If you are confused which wire goes to dark-colored screw
Mark the 2 black wires and the red wire.
You are not going to do anything with the white wire.
Connect blacks and red to any screw, turn on power, and try BOTH switches
Keep trying until correct combination is discovered
Both switches must work in all possible up-down positions before wiring is correct
Incorrect wiring will not blow circuit breaker, the circuit just doesn't work until wires are right.
Four way switch is added to 3-way circuit
Oct 09, 2010 | Garden
Installing a 7 day digital wall timer
Swylite LST100 timer has 4 wires. Red, Blue, Black, White
Timer has more wires than wall switch because timer has electric clock inside. And with + series Swylite timer, it also has led bulb that needs power.
Timer can replace ordinary on-off switch
-On-off switch has 2 screws, so 2 wires (plus ground wire) connect to on-off switch
-Three of the four timer wires are used when replacing on-off switch
-Red wire is not used, it is capped off
Timer can replace 3-way switch
-Three way switch has 3 screws, so 3 wires (plus ground wire) connect to 3-way switch
-One of the screws on 3-way switch is colored dark (it is crucial to identify the wire that comes off dark screw so timer can be wired correctly)
Lets replace on-off switch see diagram
Timer black goes to Hot wire
Timer blue goes to Load (light, fan, motor)
Timer white goes to Neutral
Timer red is capped off.
How to check which wire is Hot, Neutral and Load
Switch you are replacing has 2 wires > one is Hot, the other goes to Load
Remove these two wires. Separate wires so you can test. Turn on power. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare copper wire.
When tester lights up >> that is Hot wire >> please connect this wire to Timer black wire
The other wire goes to Load >> please connect this wire to Timer blue wire.
Now test for Neutral. Test Hot wire to other wires inside box. Neutral should be white. When tester lights up, that is Neutral. Please connect Timer white wire to neutral. IF YOU DO NOT have a neutral, you can connect Timer white to bare ground wire until you have time to drop a Neutral into the box.
Replace a 3-way switch see diagram
Three-way switch has 3 wires.
Identify which wire connects to Dark screw on switch >> and then please connect this wire to Timer Black wire.
Timer white wire connects to Neutral
Timer blue and red wires connect to other two wires that came off switch ... they connect to either one.
Oct 01, 2010 | Solar Ivory Swylite Lst100+ Back-lit...
Both 3-way switches don't work
In a situation like this , If the switches are new, then the wiring has gotten messed up. If they are old installation, then it sounds like a loose or broken wire in one of the switch boxes. check the sketches for correct wiring, making sure that the travellers between the switches are on the brass colored screws .. and check all wire nut connections and scrwew connections to be sure that all wwires are secure in their connections.
Apr 28, 2010 | Leviton 003-1755-W Three Rocker Switches
How do i wire a miniature rocker switch red/brown and black wires
Any wire that is colored is hot, except for green and white, which is ground and neutral, If you have a line coming in to your switch, and 3 loads going out, red, brown, black, then those should be the 3 lights. The white wire will be connected to white, and the green to ground. If you don't have 4 colored wires, then you have 1 switch too many. Let me know if this is making sense.
Apr 14, 2010 | Leviton 003-1755-W Three Rocker Switches
I am connecting three switchs to control one light. how do i connect using a 4 way switch
The wiring method is power into the first 3-way switch, 3-wire to the 4-way switch, 3-wire to the second 3-way switch and 2-wire to the lamp. The way you terminate the wires on the switches is only important on the black terminals of the two 3-ways. Power and load go on these, the rest are just travelers.
Nov 15, 2009 | Leviton Decora Gray Rocker 4-Way AC Quiet...
How do I correctly wire this unit?
Ok,That is 3 switches in one,You have all the wires on the post correctly? You just need to tighten them down and install into the wall box.If you are not sure of the wiring,Post details of the 3 items to be controlled by the switches and the wires in the box(How many and what color) and a wiring diagram can be provided.
May 13, 2009 | Leviton 003-1755-W Three Rocker Switches
Not sure how to wire this switch
Switch will have a commom terminal that the hot wire connects to.
The other three terminals are for the devices -- light, fan and other device.
The white wires should be the grounded wire returns for the circuits unless they are identified by color tape to be hot line side of power.
Be careful of the grounded side of circuit, can shock or kill, treat all wires as being energised. If you are not sure, use a electrical tester,
or get help.
Feb 28, 2009 | Leviton 003-1755-W Three Rocker Switches
Hamilton Beach 35030 Deep Fryer Logo
104 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
deton8 von Splosion
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
