Question about Akai Televison & Video
Akai LCT3724AD will not recognize any HDMI signals (shows "no signal"). Internal DVD works fine.Swapped sources, swapped HDMI cables, no change. Started after electricians were working on house, power
Will not recognize any HDMI signals (shows "no signal"). Internal DVD works fine.Swapped sources, swapped HDMI cables, no change. Started after electricians were working on house, power cycled TV.
    Top Expert:
  • Akai Master
  • 74,459 Answers
Firmware fault. A firmware update is necessary. Contact the authorized service center for Akai.
Posted on Dec 06, 2014
SOURCE: blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Posted on Oct 26, 2007
circuitworld
  • 335 Answers
SOURCE: TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Posted on Feb 11, 2009
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
SOURCE: My 40 inch Samsung LCD TV was working fine then
Try a new HDMI - I had a cheapo from walmart and I tried a Monster HDMI and it worked beautifully
Posted on Nov 28, 2009
Vertical stripes in picture image of new tv. Stripes appear on cable signal and dvd player signal. Have swapped hdmi cable to Av input and the condition remains. Is the tv defective?
if its new and it does this on several different inputs from different vidoe signals, take it back to where you bought it and demand a replacement.
Dec 24, 2010 | LG 42LE5400 42 in. LCD TV
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
Green dvd
if dvd is a hdmi..and your using RGB cables..swap them around..it sounds like you have the cables misplaced..if that doesn't work..then swap out the dvd player and see if the replacement dvd player does the same thing
Jan 25, 2008 | Akai LCT2721AD 27 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
Televison & Video Logo
188 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
