Question about David Weeks Cubebot
Replace broken elastic in cubebot - David Weeks Cubebot
On my slingback shoes the elastic is unraveled on both left and right shoes.
You are able to replace the elastic on them. Open the seams up and replace the elastic.
Jan 23, 2016 | Clothing Accessories
Cd can not open or close normally
Does your computer recognise that there is a CD player present?
If it has been in use for some time your elastic band may have broken!
Can you believe that? Hi--Tech driven by an elastic band. Removing the CD player and dismantling is quite a tricky problem.
Mar 02, 2014 | Computers & Internet
DVD PLAYER DOES NOT OPEN
THE LITTLE BELT COULD BE BROKEN OR OFF, I REPLACED MINE WITH A GOOD ELASTIC BAND. YOU CAN BUY A POUND OF ASSORTED ELASTICS AT A DOLLAR STORE FOR A DOLLAR.
Feb 25, 2013 | Televison & Video
My husbands Bruno's have an elastic material by the lip of the shoe. Each shoe has two of them. All of them are starting to unravel and tear. How can I get the elastic repaired/replaced? The rest of...
Elastic gores do seem to wear out first, especially if shoes are snug.
Latex rubber elastic starts as a natural plant product so will decompose on its own over time. Repeated stretching hastens the process, as does normal environmental exposure (extreme heat, sun, humidity or overly dry conditions are worse!) and accidental smudges of shoe polish, shine and/or cleaning products.
Ask your local Cobbler or Shoe Shop to fix them for you. They will remove the old elastic and stitching, and replace it with fresh elastic.
While the shoes are in the shop, they'll inspect for other, less noticeable worn areas of the shoes. The support of soles and heels may be compromised by the time elastic shows wear, affecting comfort levels.
May 16, 2011 | Bruno Magli Clothing Accessories
My battery door is broken I have to put a rubber band around it to hold the batteries where can I find the battery door
Battery doors are almost impossible to find online. I'd contact Fuji by telephone to see if they retail themselves, if not, i'd try and use the broken battery door to somehow replace the elastic band.
Nov 22, 2010 | Fuji FinePix S5000 Digital Camera
I need a complete set of poles for my timberline 4 tent, how much do they cost?
Not sure how much they cost. If the elastic is gone, you can replace elastic line and this should be a cheaper alternative, if the poles are broken, then you'll probably need to replace all.
Nov 10, 2009 | Eureka Timberline 4 A Frame Tent
Where can i send my fy500 to get the battery door fixed?
I've broken 2 battery doors now. It doesn't take much. Got the 1st one replaced under store return policy. Now it's way past the warrantee period.
I've resorted to tape and elastic bands. If you attach the elastics from opposite corner to opposite corner, it works pretty good and still doesn't block the front buttons.
Sep 03, 2009 | Mpio FY500 MP3 Player
Elmo St600 M super 8 projector sprocket will not turn
The drive belt on the porjector maybe broken. They tend to be made of rubber like an elastic band and tend to get hard and break easily. If this is the case, you may be able to substitute a large elastic band to replace the origional part.
Aug 26, 2009 | Photography
David Weeks Cubebot Logo
79 people viewed this question
Top David Toys Experts
ray gallant
Are you a David Toy Expert? Answer questions, earn points and help others
