Question about Sony KDL-46XBR4 46 in. LCD Television
Sony turn on and off no codes
The trouble seem related to temp. After warm up five to ten minutes the screen starts to break up (lose of video) into small noisy vertical line for just a second or two then the TV just shut off for about 10 second turns back ow with out any problems or trouble codes being flashed. Sometime the cycle will repeat quickly and sometime not at all. I'm thinking either the controller board or the Power Supply. Any thought will be helpful.
    Top Expert:
  • Sony Master
  • 75,386 Answers
Sounds like T'Con board fault. Contact the authorized service centre for Sony. If this is true, the T'Con board will be available only by the Sony service centre. No way to get it from open electronic spare part market. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 06, 2014
Why is my car sputtering and losing power after it warms up?
How long since a tune-up? Any applicable trouble codes? If temp related, check the coolant temp sensor. Check your throttle position sensor. Don't replace anything unless your testing points in that direction.
Oct 09, 2016 | 2000 Pontiac Sunfire
Tip
How To Check & Reset Your 2002-2006 Nissan Altima Service Engine Soon (SES)...
The following directions will help you decode your 2002-2006 Nissan Altima's Service Engine Soon (SES) light and reset it.<br /> <br /> <span style="font-weight: bold;">Obtain The Trouble Code</span><br /> <ol> <li>Turn the ignition key to the ON position and wait three seconds.</li> <li>Put the accelerator pedal to the floor and release it five times in less than five seconds.</li> <li>Wait exactly seven seconds. Put the accelerator pedal to the floor for ten seconds until the SES light flashes.</li> <li>Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.<br /></li></ol> <ul> <li>Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.) </li> <li> The next three digits blink faster (0.3 second) and have a 1 second pause between digits.</li> <li>The ECM code repeats until you turn the ignition key to the OFF position.</li> <li>You can look up the trouble codes in the Service Manual.</li> <li>If you get four blinks of ten, or 0000, the ECM indicates no malfunction.<br /></li></ul> <br style="font-weight: bold;" /><span style="font-weight: bold;">Clear The Trouble Code</span><br /> <ol> <li> Clear the code and the SES light by holding the accelerator pedal down to the floor for 10 seconds or more while the SES light is blinking.</li> <li>When the pedal is released, the ECM will erase the trouble code(s).</li></ol>
on Feb 15, 2011 | 2002 Nissan Altima
I have a 7 year old toro timecutter zero turning radius 16/42" mower. It starts and mows fine but after about 10 minutes of mowing it loses power and dies abruptly. After sitting for 10 or more minutes it...
could be a ignition unit (s)breaking down when it getts hot ?
could be a tank breather not working or a restriction in flow of fuel
could be a valve not opening fully or closing fully ie tight valve
fit in line ignition tester and run unit and see if spark disapears when unit gets hot if so ignition prob if not its other problems
worth a look
cheers
Jun 30, 2010 | Garden
My 1999 Tahoe cranks up but will not stay running. Seems like fuel pump, filter, or injectors. Any suggestions?
check theft system for problems with program(dealer)..disconnect battery for about five minutes,reconnect and try to start,if starts and then stalls leave key on for ten minutes exactly...then turn key to off position for 15 seconds..then start...if starts allow to run for ten minutes..
Dec 27, 2009 | 1999 Chevrolet Tahoe
98 Buick Regal -engine quits
ok its one of two things you need to check when it cuts off if you have spark or fuel if you lose fuel pressure replace pump it gets hot and makes noise like its running but its not pumping fuel and if you lose spark you need to replace ignition control module has a hair line crack in it and when gets hot the crack expands and loses contact and wala no spark
Aug 15, 2009 | 1998 Buick Regal
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go...
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Showing a engine service soon
The code that it is throwing is P0128, "Coolant Temp Below
Thermostat Regulating Temp. If your car is not running hot try this. If it is running hot take it to the shop or replace your thermostat yourself this is probably the problem.
Simply disconnect your battery, turn on the headlight switch for about five to ten minutes, and re-connect the battery. This is pretty simple, but will likely result in you losing your radio presets and perhaps some other small things like that.
This will reset your light. If it comes back on your thermostat or temper sensor may be bad.
Good Luck Hope this helps>
Jan 18, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Sony KDL-46XBR4 46 in. LCD Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
